displaying posts 276 to 300 of 339
Pages (14): first .. 11 [12] 13 .. last
Author Subject: *FINISHED* SUPERCHARGER KITS
midlife
Post #276
And theres me thinking that I would be the only one with silverDoh
Cool
Team 330™Cool
Team "no front end or engine"
Posted 25th Oct 2007 at 22:43
puglover Banned!
Post #277
i went for silver as well but have since changed my mind to black Ninja
Posted 25th Oct 2007 at 23:13
zac
Post #278
trustplum wrote:
Sounds like next week some time, take it you've gone for silver too then!
+ 1
Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers
- Phase 3 GTi-6 (409hp 'charged weekend toy)
- Phase 2.5 Rallye (daily driver)
R.I.P Pete Sims
Posted 26th Oct 2007 at 00:26
chris with a pug
Post #279
I ordered a gold one and my car is silver
Posted 26th Oct 2007 at 02:09
Post #280
I have gone for the silver as well, they look awesome. Yes Thumbs up
Posted 26th Oct 2007 at 02:20
midlife
Post #281
Unsure
Laugh my ass off
Team 330™Cool
Posted 26th Oct 2007 at 04:54
rich_w
Post #282
These are the guide pullies that go onto the SC Bracket. As discussed, I was going to use Peugeot ones, but these should last a lot longer. They will be hard-anodized for wear resistance, and they have been increased in size by about 6mm over the Peugeot items, this is to reduce speed and extend bearing life Cool
Contact Details:
07732 822546
Posted 27th Oct 2007 at 20:45
puglover Banned!
Post #283
cool, yeah ill have a tensioner pulley as well mate. This conversion is just getting better and better. Thumbs up
Posted 27th Oct 2007 at 23:32
chris with a pug
Post #284
how will you fit the tensioner pully?
Posted 27th Oct 2007 at 23:40
rich_w
Post #285
It replaces the auto-tensioner pulley like for like, one T40 bolt Wink
Contact Details:
07732 822546
Posted 28th Oct 2007 at 00:31
gtisid
Post #286
is this the tensioner pully that breaks on some gti6s and causes cambelt failiure or am i barking up the wrong tree here?
if this is an upgrade of the standard item that wont break and cause premature cambelt failiure i think everyone in the club should have one
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 28th Oct 2007 at 00:40
mabgti
NV motors
Post #287
wrong tree. AUXILLARY belt guide pulleys. Not cambelt onesNo
I'll have one too richThumbs up
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Oct 2007 at 01:04
gtisid
Posted 28th Oct 2007 at 01:01
rich_w
Post #289
There has been a little 'Design Development' on these regarding the ICV mounting location.
The plan was to mount the ICV on the inlet manifold (as it currently is on your standard engine) and use a non-return valve on the ICV to prevent boost escaping under throttle, but this would still allow the engine to breather under vacuum (idle/part throttle) conditions.
The problem I had was sourcing a suitable non-return valve to work and fit into the ICV - so this has required a change of plan (at considerable expense to me BTW!!).
The ICV will now be mounted between the TB and compressor, as on my car.
The reason this wasn't done to begin with was because the Peugeot TB (which I wanted to retain) has a nasty breather assembly sticking out the front of it (black plastic thing with yellow connector) which would foul the ICV.
The solution now, as can be seen by the photo's, was to get a laser-cut blanking plate made up for the manifold, get a laser cut-blanking plate made for the TB (to replace that nasty breather assembly I mentioned), machine a mounting plinth for the ICV, and re-machine the MAP sensor housings to accomodate the ICV and EVAP (fuel tank ventilation) purge elbow (brass elbow ontop of housing).
Anyhow, its all been done now, will work, and looks neat. The only thing to deal with is crankcase ventilation, for which there are several options:
1. Fit beather filter to rocker cover hosetail.
2. Use oil catch tank
3. Breathe the crankcase gases back into the inlet sytem as per standard set-up.
The SC Kit will include a threaded 90 deg. 14mm plastic elbow, which can be mounted into the air-filter end plate for Option 3. This is essentially whats been done to my car, and it works well. Although I understand some people may want oil catch tanks/breather filters for the 'bling bling' effect.
The photo's show everything bar ICV ( I don't have one to hand) but I hope you can clearly see where it bolts down.
Cool
Contact Details:
07732 822546
Posted 28th Oct 2007 at 04:42
rich_w
Post #290
This pic shows the breather plate on the standard GTi-6 TB which has been binned 'cos it gets in the way (and is a pain in the arse generally).
This is the setup on my car, to show how the ICV will be mounted in identical fashion:
Contact Details:
07732 822546
Posted 28th Oct 2007 at 04:52
gazzerdaman
Post #291
Doesn't that breather incorporate a small heater to prevent the throttle body from icing up in the winter?
Gary
Cherry Red GTi 6
Posted 28th Oct 2007 at 06:18
smighall
Smeg-all
Post #292
That a seperate one Gary, on the bottom of the TB.
Meh
Posted 28th Oct 2007 at 07:17
rich_w
Post #293
That's correct - but IMO its the biggest waste of time ever, hence i'm not to worried about removing it.
I'm not using one, and i've not ahd any problems last winter..
Anyhow, im sure the charger generates more heat than that little heater!
Contact Details:
07732 822546
Posted 28th Oct 2007 at 14:02
russbez
Post #294
very nice!
rich i think im having trouble replying to your pm
let me know if you get one from me Doh
My Rallye project thread
Posted 30th Oct 2007 at 04:13
gazzerdaman
Post #295
Thumbs up
Sorry if it sounded like I was trying to pick holes, I was just curious
Gary
Cherry Red GTi 6
Posted 30th Oct 2007 at 05:01
rich_w
Post #296
I dont know how to describe these manifolds other than FOOKING LAIRY Love
Contact Details:
07732 822546
Posted 2nd Nov 2007 at 02:59
gtisid
Post #297
those black ones look sweet
pugless
Posted 2nd Nov 2007 at 03:08
Welly Forum Admin
Post #298
Sexual
Vrs power!!
Posted 2nd Nov 2007 at 03:09
rich_w
Post #299
Here's some pics of the bracketed up charger, with 6082 T6 Billet Alloy guide pullies Cool
And some pics of the inlet assembliy, showing ICV mounted now Cool
Contact Details:
07732 822546
Posted 2nd Nov 2007 at 03:13
farmer
Post #300
Im definatly thinking now that the black manifold was the right choice Smile Yes
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 2nd Nov 2007 at 03:50
