Author Subject: Torsion Bar Lowering FAQ
nwphoto
Club Snapper
This is the method I used to lower my own Peugeot 306 GTi-6. I would like to point out that the torsion bars had previously been removed, cleaned & greased & refitted. The o/s torsion bar was seized into the trailing arm, which is very common if they've been in for a few years & needed a 10 tonne hydraulic puller to free it. I would suggest you make sure both bars move freely before making any adjustments.
Also, this is only a guide & may contain errors. If you follow these instructions to adjust your own suspension & it all goes horribly wrong, it's not my fault. You have been warned.
If possible, position the car on perfectly level ground & take measurements of the wheel arch heights for future reference. Don't be surprised if they're slightly different from side to side (up to about 5mm)....nothing's perfect.
Jack up the rear of the car & support it on axle stands, remove both rear wheels & release the handbrake.
Disconnect both shock absorbers from the trailing arms.
nwphoto has attached the following image:
Posted 27th Apr 2007 at 02:37
nwphoto
Club Snapper
Below is the view of the trailing arm assembly on the passenger side (n/s), behind the rear wheel. The drivers side (o/s) is similar, but the torsion bar ends swap positions.
Posted 26th Apr 2007 at 18:00
nwphoto
Club Snapper
Remove the anti-roll bar end plate fixing bolt (13mm spanner) from both sides of the car. The plates can then be rotated out of the way to allow access to the ends of the torsion bars. If the plates are very difficult to turn, they may need to be removed to allow the trailing arms to rotate independently. To separate the end plate from one end of the bar, remove the platic plug & screw an M12 bolt (Ford wheel bolts are M12) into the hole where the plug came out & keep tightening until the plate pulls off, see below. This can be done from either side. You'll need to prevent the plate turning as you do this, so loosely re-insert one of the fixing screws.
Posted 6th Jul 2007 at 05:13
nwphoto
Club Snapper
Pull out the anti-roll bar.
Posted 26th Apr 2007 at 18:01
nwphoto
Club Snapper
Remove the Torx head countersunk screw from the end of the torsion bar.
Posted 26th Apr 2007 at 18:02
nwphoto
Club Snapper
Clean all the dirt & rust from around the offset washer, then, using a small punch, tap the washer out of it's groove & prise it out.
From the other side of the car, remove the nut & washer from the fixed end of the torsion bar.
Posted 6th Jul 2007 at 05:22
nwphoto
Club Snapper
This is what the screw looks like, in case you were wondering. It's purpose is to adjust the length of the torsion bar & hence the clearance between the trailing arm & the seal in the end of the beam tube.
nwphoto
Club Snapper
Stick a piece of masking tape to the wheel arch directly above the hub & measure the distance from a point on the hub to the underside of the tape. Write this measurement on the tape so you don't forget it (because you will). When taking the measurement, the hub must be hanging under it's own weight, with no handbrake cables, shocks or anti-roll bar restricting it's movement. If you tap it, it should bounce up & down freely.
Posted 26th Apr 2007 at 18:05
nwphoto
Club Snapper
Position a jack under the hub & raise it by 5mm. This will take the weight of the hub & remove all tension from the torsion bar.
nwphoto
Club Snapper
Screw a slide hammer with an M8 screw thread into the end of the Torsion bar.
Posted 26th Apr 2007 at 18:06
nwphoto
Club Snapper
Pull the torsion bar out of it's splines in the trailing arm....
Posted 26th Apr 2007 at 18:07
nwphoto
Club Snapper
....& fixed anchor point on the other side. Leave the slide hammer in place.
Posted 26th Apr 2007 at 18:08
nwphoto
Club Snapper
Jack up the hub by the amount you wish to lower the ride height. The new measurement will be the figure you wrote on the tape, minus 5mm, minus the lowering amount. i.e. if you're original figure was 420mm & you want to lower by 25mm, the new figure will be 390mm.
Re-insert the torsion bar. If it doesn't slide in first time (it probably won't), rotate the bar & try again. Eventually you will find a position where both ends of the bar will just push in. If you left the slide hammer in the end, it'll be easy to do this on your own, otherwise you'll need someone under the car aligning the other end of the bar with the fixed bracket.
Remove the slide hammer.
Now do the same for the other side of the car.
When that's done, temporarily refit the wheels & lower the car to the ground to check the height. Bounce the car a couple of times to allow it to settle.
If all's ok & you're happy with the ride height, get the car back on the axle stands & remove the wheels.
Refit the offset washer & tap it into position, aligning the hole with the torsion bar.
Before fitting the countersunk screw, refit the slide hammer through the washer & pull the torsion bar hard up against the washer. Then, remove the slide hammer & fit the screw.
Check the clearance between the trailing arm & it's bearing seal & adjust it to 0.5mm using feeler gauges, tapping the arm in or out with a mallet.
At the other end of the torsion bar, turn the screw anti-clockwise until it just stops against the end cap. Refit & tighten the nut & washer, then re-check the trailing arm/seal clearance.
Re-attach the bottom shock mountings. You may need to jack up the hubs slightly to get the bolt holes to line up.
Refit the torsion bar at one end & loosely fit the hexagon headed fixing screw. From the other end, push the other plate on the end as far as it will go. Screw in an M8 screw with a nut & washer on, through the plate, into the anti-roll bar & tighten the nut to draw the plate onto the bar until there is 1mm between the plate & the trailing arm.
Posted 6th Jul 2007 at 05:16
nwphoto
Club Snapper
Tighten the fixing screws & refit the plastic plugs.
Refit the wheels, check you have no parts left over & go for a drive.
Remove the tape you stuck to the arches.
Posted 26th Apr 2007 at 18:15
nwphoto
Club Snapper
quote:
Is it as simple as it looks NW? I've thought about following your guide before but have always feared screwing up big style Blink
If the torsion bars aren't seized, yes it is that simple Wink
Posted 26th Apr 2007 at 19:02
rich_w
It depends.
The only bit you will struggle with is pulling the bars out.
On my car, a standard size slide hammer did fook all. Well, in fact it pulled one of the bars out, but only at the captive end, meaning it was stuck in the trailing arm, and the slide hammer was pulling the trailing arm out of the beam with the torsion bar.
We then upped the anti.
Using a 20KG slide hammer (yes, you read that right, 20KG!) we tried again. It pulled the passenger torsion bar free at both ends, no problems.
Then it was back to the drivers side, which was still stuck in the trailing arm!
Even with the huuuge slide hammer, it wouldn't budge. To give you an idea of how much force this thing gives, it nearly pulled the car off the axle stands, and snapped two M8 slide hammer attachments due to the stretch.
In the end, I had to undo the brake caliper and take the trailing arm off the car. Once off the car it came out OK with a big drift and copper hammer.
All sorted now Big grin
Contact Details:
07732 822546
Posted 26th Apr 2007 at 19:06
This thread has been locked
