Author Subject: Torque Settings
smighall
Smeg-all
As i was looking for something and couldn't find it on here, i thought i'd sling up the torque settings from Autodata for you lot.
Meh
Posted 18th Mar 2007 at 22:04
Head
Stage 1 = 26lb ft
Stage 2 = 52lb ft
Bearings
Stage 1 = 26lb ft
Stage 2 = 52lb ft
Oil Pump + Sump Bolts
= 15lb ft
Sump Drain Bolt
= 26lb ft
Flywheel
= 37lb ft
Flywheel to clutch
= 15lb ft
Crank Pulley
= 89lb ft
Camshaft Cap + Rocker Cover
= 8lb ft
Inlet Manifold
= 15lb ft
Exhaust Manifold + Oil Pressure Switch
= 26lb ft
Front Hub, M20, > VIN 808980
= 196 lb ft
Front Hub, M20, VIN 808980 >
= 181lb ft
Front Hub, M24
= 237lb ft
Rear Hub
= 141lb ft
Track Rod End
= 26lb ft
Caliper to Carrier
= 22lb ft
Carrier to Hub
Front = 81lb ft, Rear = 98lb ft
ABS Sensor
= 7lb ft
Wheel bolts
= 63lb ft REMEMBER THIS ONE!
Posted 19th Mar 2007 at 01:38
charlie
Posted 19th Mar 2007 at 01:39
Or just multiply by 0.74
Posted 19th Mar 2007 at 01:41
You probably wouldn't even want 1/16h of a turn tbh.
Posted 19th Mar 2007 at 01:59
david932
very useful, just what i was looking for, thanksSmile
also own a 192bhp williams clio...eats scoobys for snacks!
Posted 19th Mar 2007 at 02:07
miles
I don't do the big ends up to those setting's unless I use new std bolt's, It's the same in most new 205 books use that but the early one says around 40lb's ft from memory
www.pugracing.com
Posted 19th Mar 2007 at 03:10
This thread has been locked
