Author Subject: boot carpet clip fittings, what glue?
jimmyhackers
got me a set of four brand new carpet bung holders....
tried rtv....ripped right out the next day....what glue should i use to stick them in better?
Posted 28th Feb 2025 at 18:44
jimmyhackers
superglue worked for all of 2 days :s
im wondering if i should rough up the surface of the bungs a little with some grit paper and try glue again.
i have two part epoxy but am reluctant to use it just yet.
Posted 20th Mar 2025 at 21:22
jord294
You mean for boot carpet?
Posted 21st Mar 2025 at 09:16
from memory its a 2 part piece, white section goes into the floor under the carpet, the black top hat piece goes in through the lot and secures it.
Posted 21st Mar 2025 at 12:50
jord294
Poor design imho.
Posted 21st Mar 2025 at 17:55
jimmyhackers
poor design indeed....i got a set of 4 brand new 205 ones which are identicle to 306.
the black hat is meant to work like a screw/wall plug and expand the white lower, securing it....but yeah poor design.
ive roughed up the surface of the white bit with a rasppy file and re superglued...
i figure half the problem is my new underlay is foil backed/topped and somewhat slippy.....i might try and spray some tacky rubber type glue over it to make it a bit more grippy.
Posted 29th Mar 2025 at 10:38
never had an issue with them
Posted 19th Apr 2025 at 10:44
