Doesn’t get louder with revs…
Any ideas?
The cambelt is due to be changed, does anyone know of someone capable near Bishops Stortford area to do this?
I went to Norfolk previously for a change by one of the members on here.
| Author | Subject: Knocking from cambelt cover when warm…. |
Robbo1830
Newbie Location: Bishops Stortford Registered: 29 Sep 2021 Posts: 6 Status: Offline |
So, started up this morning after a long while sitting, all good until warmed up when a knock could be heard, seems to be in the cambelt area, not from the block.Doesn’t get louder with revs… Any ideas? The cambelt is due to be changed, does anyone know of someone capable near Bishops Stortford area to do this? I went to Norfolk previously for a change by one of the members on here. |
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
My Xsara VTS did something very similar after being stood for a while whilst I located a radiator for it. Belt had gone slack.Easy enough to take the cover off and check the tension. Wouldn't drive it until you have checked, and if it's loose, don't drive it at all. ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
Carl GTI
Junior User Location: Tripoding at Brands Hatch Registered: 11 Aug 2015 Posts: 85 Status: Offline |
If its not too far for you, I can highly recommend a place in Dartford that has been doing my Xsara cambelt changes and servicing for over 15 years. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Anyone good in the North-West who can do them properly?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Robbo1830
Well, I’ve just been quoted £690 to change belt and pulleys….I had already driven her as this only became audible when warmed up fully….. I’ll take a look at the weekend re the belt slack before starting up again.👍 |
Robbo1830
So I can get the parts for £130? Seems like a lot of labour cost!!!! |
Robbo1830
depends on their hourly labour rates, you're not far from london and labour rates around there can be pretty mental.its also a 6 hour or so job on autodata from memory. I know a lad at Thurston engineering in Ongar that knows these engines, probably half an hour from you, Baz may know someone or take it on himself. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
I used to do these for £150 labour, they are overcharging at that price!________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
jord294
rudolf wrote: Anyone good in the North-West who can do them properly? North Wales i am. Did you sort it? ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Take great care at this point mate. Had a pretty new cam belt go on me a few years back where unbeknown to me, the outer cam belt cover was poorly fitted and shredded my belt. Only on tickover, but had no idea until it happened. Would whip the outer cover off and have a good look before running the engine any more. |
