Thanks
Rouben.
| Author | Subject: Top engine mount, where to buy. |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
Hello all, my 21 year old '6' engine mount needs replacing, not having much luck in sourcing a new one. Are pre 97 ones and year 2000 ones the same?. Or is the same engine mount used on other cars too.Thanks Rouben. |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
Are'nt they the same for all XU engines? Or maybe even all 306 engines in general?________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
RallyeP6
That's what I am hoping, it could be just the damping or resonance characteristics which may be different for engines, but I think mechanically they should still fit. |
S8-Tom
Regular Location: Chichester Registered: 02 Feb 2018 Posts: 356 Status: Offline |
RallyeP6 wrote: That's what I am hoping, it could be just the damping or resonance characteristics which may be different for engines, but I think mechanically they should still fit. The main engine mount (top, drivers side) is the same for GTi, XSi, 1.8 & the diesels (so XU block stuff). The 1.4 and 1.6 TU engine have a different part number. It's worth getting genuine or something like a Baker BM set as the one's supplied by motor factors seem to be too soft. ________________________________________ 1343Z4 coolant hose o-rings for sale198131 injector o-rings for sale |
RallyeP6
Thanks for the advice Tom, I will have a look again then. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I got a brand new looking one off a 406 which was the same part number.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
jord294
Genuine one here bnib________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
if your a real nutter like me, you can always just pack/glue either side of the two rubber pyramid bits with some lino or thin wood or plastic.________________________________________ the world is changed by people in sheds |
