displaying posts 1 to 2 of 2
Author Subject: Exhaust help
pugfrank
Hi all,
I'm having to daily my 6 now Thumbs up
Not so good bit is the cat back s/s exhaust system I fitted a year or so ago has got really boomeyey !! Sad
I have a standard exhaust that I just want to fit back on, only problem is that the garage when they fitted the s/s system cut and repaired the tube coming off the CAT so the standard system wont just bolt back on Unsure
Can anyone suggest a fix around?? Is there an bolt on exhaust fitting that will work??
Thanks in advance.
Posted 23rd Feb 2021 at 17:06
anth
You can either replace the CAT (probably hard to get hold of now) but the 'easiest' fix I would guess. Or you will need to butcher your s/s and standard system to make it fit.
It may pay to just take it to a garage, give them the exhaust and just ask them to make it happen! Smile
Posted 6th Mar 2021 at 19:37
