Author Subject: blasting engine parts (thermostat housing + vac pump)
i've got loads of bits at the powdercoaters at the moment being done for my engine.
could the thermostat housing, and the outlet / take off (metal one for a 205 gti6 conversion) be blasted with steel media and coated or is it too soft? i recall reading you couldn't blast them and best to do them with VHT paint after
same question with the vacuum pump - if i strip it down, will it be ok to blast/coat?
anyone?
Posted 28th Oct 2020 at 10:31
jord294
Vapour blasting is best
Posted 28th Oct 2020 at 11:43
S8-Tom
Did mine this way. There's some pics on post #117 of my project thread that show the thermostat housing and vacuum pump back on the engine after blasting and a coat of VHT paint.
Posted 28th Oct 2020 at 20:42
alcon
I blasted mine using 60/80 grit aluminium oxide with no issues
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 28th Oct 2020 at 18:56
