Author Subject: Rear Beam setup
eiei0
Hi All
I have just changed the torsion bars in my axle as the were only 19mm, I seen in one of the guides you need to set the gap to 0.05mm? Can someone give me a idiots guide to doing that, I know you use the double ended threaded bit with the cut for a screwdriver, do I hold it and tighten the 13mm nut ?? Does that pull the trailing arms onto the tube?? Where do I measure 0.05mm ??
Thanks
Trevor,
Posted 6th Oct 2020 at 20:59
eiei0
Posted 6th Oct 2020 at 21:02
jord294
Feeler gauge between seal and arm
Posted 6th Oct 2020 at 22:01
