displaying posts 26 to 27 of 27
Pages (2): 1 [2]
Author Subject: Black 306 GTi 6 Project
cully
the rpo number 08163 should be on a sticker on the car or painted on a strut top or on the back of the bulk head engine bay
this is the factory build date and it works out to "16 March 1999" build date and DVLA first reg date is 5 feb 2001
there is something strange about your car says warranty started 1990
it is fitted with a rear brake load compensator so defo a ph 2
Vehicle characteristics
Vehicle family 306 RESTYL
AS/RP N° 08163 81 2 0353
Warranty Start Date 01/01/1990
Engine serial number 10 HKH8 3002048
BER e2*93/81*0152*02
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 306 RESTYL
SILHOUETTE 3 DOOR SALOON
TRIM LEVEL SPORT 2
ENGINE INJECTION XU10J4RS
TRANSMISSION BVM6
PAINT TYPE NON-METALLIC PAINT
INTERIOR TRIM TYPE ALCANTARA "C7"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BE3/6
ENGINE (TYPE) XU/XUD
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE GTI 6
TRIM LEVEL SPORT 2
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X19
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) UPPER ENGINE EMISSION CONTROL EEC 95 L3/W3
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
ENGINE TEMP. NOZZLE ENGINE WATER TEMPERATURE BOX
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
POWER VARIATION (ENGINE) STANDARD POWER
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
RHEOSTAT RHEOSTAT
VEHICLE TECHNICAL DEPOLLUTION L3 VEHICLE TECHNICAL DEPOLLUTION
FAN 2 FANS , 2 RATES
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI
Gearbox Transmission
TRANSMISSION BVM6
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 77
WHEEL STYLE ALLOY WHEEL CYCLONE
CLUTCH CABLE CLUTCH TAKING UP OF PLAY
AIR CHAMBER WITHOUT INNER TUBE
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
DIFFERENTIAL (GEARBOX) SUPERIOR GEARBOX DIFF
TYRE (SIZE, TYPE) 195X55X15 V TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE BE3R MANUAL GEARBOX
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 24
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE WITH COMPENSATOR SLAVE
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION IMPROVED SUSPENSION
BRAKE ASSOCIATED VARIANT ADDITIONAL ABS5 BOSCH
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
AERIAL SHORT ROOF AERIAL
WIPER ARM FRONT BLADE WITH DEFLECTOR
HOOD WITHOUT HOOD
REAR SPOILER ASSEMBLY WITH REAR SPOILER
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=40 + SIDE SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
HARD TOP WITHOUT HARD-TOP
EXHAUST TAILPIPE TRIM WITH EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK BUMPER GRILLE NOT CLOSED
BUMPER FULL BODY COLOUR SPORT UP TO MOD2000
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES HANDLE+MIRROR BODY COL/SMOOTH NEUTR RR QUART PANEL
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
REAR SCREEN WASH REAR SCREEN WASH
SUN ROOF FIXED ROOF
HOOD COLOUR WITHOUT HOOD
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) PIVOTING REAR QTR GLASS
Interior fittings
SIDE ARMREST (TYPE) LATERAL ARMREST FOAM FR + MOULDED RR
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
REAR HEAD RESTRAINT JOINTED REAR HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITHOUT REAR ARMREST
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
LUGGAGE COVER WITH LUGGAGE COVER
REAR SEATBELT RR RETRACT BELT+STATIC LAP
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
CONSOLE LONG CONSOLE WITH AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT THERMOSLEEVED DASHBOARD + CREADEC PANEL
MISC. INT. LAMPS MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS) 5 DIALS WITH LUMINOUS NEEDLES
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER 4 SPEAKERS (2 COAX/FT DOORS+2 BICONICAL/RR SHELF)
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT INCLIN DRIVERS SEAT SQUAB FIXED LAT+LUMBAR BEARING
FRONT PASSENGER SEAT ADJUSTMENT INCLIN PASSENG SEAT SQUAB FIXED LAT+LUMBAR BEARING
ROOF CONSOLE LONG ROOF CONSOLE
CHOKE CONTROL WITHOUT CHOKE FLAP CONTROL
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC COMPACT-DISC PRE-EQUIPMENT
REAR WINDOW LIFT WITHOUT REAR GLASS LIFT
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE OIL TEMP + LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG LATERAL AIR BAG
PASSENGER AIRBAG PASSENGER AIRBAG
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT SEPARATION GRILLE
RADIO RECEIVER LEVEL 4 RADIO RECEIVER
REFRIGERATION REGULAR AIR CONDITIONNING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
WEAR INDICATOR WITH BRAKE WEAR WARNING LIGHT
INTERIOR PROTECTION W/O PROTECTING NET
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
TRIM ADAPTATION LEATHER CUSHION AND LEATHER BUTT
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL SPORT LEATHER STEERING WHEEL 3 BRANCHES
STORAGE SPACE LOCKS LOCKING GLOVEBOX
Electrical
ALTERNATOR ALTERNATOR 90 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 2 IR REMOTE CONTROL KEYS + 1 UNIQUE MAIN KEY
DOOR SEAL SEAL DIRT EXCLUDER
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT 30 FUSES BOX
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Posted 29th Oct 2020 at 19:47
pug_306
General information
PRODUCT TYPE CAR
TRIM LEVEL SPORT 2
TRANSMISSION BVM6
BADGE GTI 6
TRIM LEVEL SPORT 2
Fuel supply-Engine
RHEOSTAT RHEOSTAT
TRANSMISSION BVM6
ABS WITH ABS BRAKES
Body fittings
HORNS HORNS-HARMONY
HOOD WITHOUT HOOD
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS HORNS-HARMONY
Miscellaneous
Do you have any additional info on this cully? LOL LOL LOL LOL
1992 205 GTi6
205 Turbo 340bhp
Posted 30th Oct 2020 at 10:40
Pages (2): 1 [2]
