Author Subject: Aftermarket Tube
PAG306
Do i need to be concerned that where the tube sleeve & cast iron end cap butt up flush against each other on the inside they're slightly off centre Crazy or will it be ok when the inner & outer bearing's are installed Unsure Ive taken a pic but can't seem to upload it Dunno
Posted 1st Oct 2020 at 01:50
jord294
When you say aftermarket, you mean chinese version?
If you'd of asked I could of supplied you genuine
Answer to question is sometimes they don't sit flush
Posted 1st Oct 2020 at 06:35
PAG306
I thought you only sold fully rebuilt axles that's why i bought this tube but the job is now turning into a nightmare & my mot runs out next month Sad
Posted 1st Oct 2020 at 11:10
stef306
The tubes them self's are fine, it's whats fitted to them is where the issues occur.
1990 205 gti6 supercharged
Posted 1st Oct 2020 at 21:17
PAG306
Do you mean what bearing kit's fitted as the tube internal looks fine, its where the end butts up against the tube that you can see the internal discrepancy & in my eyes surely there should be an equal distance all the way around the circumference so the outer bearing & inner bearings run parallel or am i just being too fussy & even genuine tubes are like this Roll eyes
Posted 2nd Oct 2020 at 00:02
stef306
they are aftermarket tubes at the end of the day, theres going to be some slight differences. The way i see it is - aslong as it holds the bearings in the correct depth and manor and everything else fits as it should you cant go wrong. Ive used a fair amount in my time i just remove everything thats fitted to it and replace with genuine.
Posted 2nd Oct 2020 at 20:20
PAG306
So would you say the internal discrepancy is pretty normal even on genuine tubes & wont effect anything aslong as i swap out the cheap bearings installed ?
Is the SNR KS 559.00 bearing kit any good as thats what most folk seem to use Roll eyes
Posted 2nd Oct 2020 at 21:31
