Author Subject: 24mm torsion bars
stef306
Hi all,
Its been awhile since I've built a beam with 24mm torsion bars but does anyone have a rough shock height, I've got some data but I'm not convinced it's correct.
Stef
1990 205 gti6 supercharged
Posted 31st Jul 2020 at 21:22
stef306 wrote:
Hi all,
Stef
Stef what sort ride height you after ?
I run 25mm and can give you a Rough dummy shock height ?
That any use
But I’m a bit lower on the front and rear than most ?
Posted 2nd Aug 2020 at 11:27
stef306
Damien I've messaged you
Posted 2nd Aug 2020 at 20:52
jord294
stef306 wrote:
Hi all,
Stef
I had a vts axle with 25mm torsion bars znd was running 307mm. That was on a track car
Posted 2nd Aug 2020 at 21:29
stef306
It's going on a maxi running 18s
Posted 2nd Aug 2020 at 22:54
jord294
The axle i supplied a maxi owner with 25mm bars i set to 301mm, as car will be used for sprints
Posted 3rd Aug 2020 at 08:24
Got it Stef Thumbs up
I run 25mm
Mines set at 304mm Stef
Posted 3rd Aug 2020 at 20:13
