https://www.ebay.co.uk/itm/febi-32755-Needle-Bearing-Kit-Peugeot-5132-49-S1/174267069230?hash=item289320732e:g:G5gAAOSwHNheqv4Q
| Author | Subject: Bearing kit |
PAG306
Newbie Location: uk Registered: 23 Jun 2020 Posts: 26 Status: Offline |
Anyone used the Febi bearing kit & is it better than the SNR one that most people seem to use ?https://www.ebay.co.uk/itm/febi-32755-Needle-Bearing-Kit-Peugeot-5132-49-S1/174267069230?hash=item289320732e:g:G5gAAOSwHNheqv4Q |
jord294
Why bother when genuine kits are still available from main dealer 5132.62________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
PAG306
jord294 wrote: Why bother when genuine kits are still available from main dealer 5132.62 I thought the main dealers were supplying these kits with the inferior bearings since 2009 ish & that's why people started buying the SNR kit with the OE bearings or buying them separately |
jord294
Afaik, only 205/309 outer bearings suffered, as bearings came with half the amount of needle rollers. But if you know where to look, bearings with full amount of needles can be sourced elsewhere. While genuine 306 kits can still be bought, I'll be using them. Snr quality is poor compared to genuine parts________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
