Author Subject: What is the Difference Rear Hubs
eiei0
See on the parts website there is 2 listings for the rear hub,
What is the difference, is they newer one any better,
Anyone have a part number for the rear beam pins,
My car is the older one afaik
Posted 25th May 2020 at 15:47
jord294
Hubs vary on year. Early axles had a shorter stub axle pin. 2 types of hub cap too.
Hub cap with a dome to it is the longer pin and newer hub.
Trailing arm shafts are 5176.17. Over £125 each from main dealer. I don't believe in buying the cheap shafts on ebay
Posted 25th May 2020 at 18:09
eiei0
Thank for the reply, that PN is for the inner shaft,
It's the Pin that the hub bolts on to I am after,
P.S ABS Sensors Smile
Thanks
Posted 25th May 2020 at 19:23
jord294
You'll struggle to find stub axle pins new at the correct length
Posted 25th May 2020 at 20:11
eiei0
Posted 25th May 2020 at 20:26
jord294
I wouldn't trust anything spoox told me
Posted 25th May 2020 at 20:31
eiei0
Ok Thanks,
So what about these ones are the right
https://www.kamracing.co.uk/car-tuning/peugeot/peugeot-306/suspension/peugeot-306-kam-racing-gpn-rear-stub-axle-disc-brakes.html
Or are these parts not actually available,
Posted 25th May 2020 at 20:41
alcon
I don't think these are the correct ones. I looked at these before and when compared to the originals that came off the car, there was a big difference in the length of the splines at the fat end. My splines were much longer (ie. came further up the shaft) than the splines shown in that photo.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 26th May 2020 at 08:29
alcon
eiei0 wrote:
Ok Thanks,
They're the same as the ones I bought although I got mine from specailtuning.co.uk
1999 Rallye (black)
Posted 26th May 2020 at 08:35
eiei0
Spook got back to me and said that the listing is for a 106 GTI not sure why it's listed as being for a 306 then??
They have another listing for a super heavy duty pin and he said it's for a 306, I'm not fulfilled with confidence by them,
Kam racing said there is oem size just stronger, and takes the original hub now all I need to work out is what do the classify as the original hub,
I used to have a full grp A 306 rally car and had terrible issue with the rear stubs, ruined half a dozen bearings before I found out guy had changed stubs to 1.6 205 GTI and a machined hub,
Posted 26th May 2020 at 13:37
