Author Subject: Dial Test
cdgray
Can someone remind me the process to test the speedo and rev counter dials?
I have done this test before. I remember it involves pulling a fuse and when pull back in the dials move in unison to the maximum range then drop back to zero, but I can’t seem to remember the whole process and just pulling fuses doesn’t work!
Chris - Phase 3 Moonstone GTi 6
Posted 10th May 2020 at 15:12
go for a drive?
Posted 10th May 2020 at 16:20
cdgray
Thanks!
I already know the rev counter isn’t working and I’m trying to locate the issue. I suspect it is the loom somewhere but wanted to double check the dial on the clocks still works first and I know there is a method to do this test.
Posted 14th May 2020 at 23:13
jeffers Forum Admin
You tried disconnecting the battery, waiting five then reconnecting?
Team Running Engine again!
Team Negative Camber!
Posted 18th May 2020 at 06:44
Joep
My phase 1 XSI had an engine swap (RFS fitted) and had issues with the rev counter. The cause of it not working was the BMC CDA slamming against the connectors at the front near the radiator. Now the BMC CDA is fixed to the gearbox, I have my rev counter back working.
Is it the same for all phases?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 18th May 2020 at 07:29
