displaying posts 1 to 2 of 2
Author Subject: Supercharger kit & forged engine 400bhp
birk
Forged engine & Supercharger Kit 400bhp
Rotrex C30-94 Supercharger with 10-row oil cooler and complete oil circuit
Supercharger brackets and pulleys
Inlet manifold and throttle body with sensors
Intercooler and boost pipes with hoses
Slimline Fans
K&N air filter with air scoop
ECU with 400bhp map
Machined alloy 2" - 2.5" reducer for supercharger outlet
Fuel system
4 BAR Fuel Pressure Regulator
Walbro External 255LPH Fuel Pump
Wiring and Relays for Fuel Pump
Fuel Swirl Pot
Bosch Injectors
ENGINE
Forged Alloy Low Compression Pistons Forged Steel Connecting Rods
Race Quality Big End Bearings
Heavy Duty Main Bearings
Thrust Bearings
Crankshaft Oil Seal
Crankshaft Oil Seal
Head Gasket uprated
ARP head studs
Timing Belt Kit inc. All Tensioners
Waterpump
Seal for Oil Pathway Cover
End Bearing Cap Seals
Camshaft Oil Seals
Oil Cooler Seal
Thermostat Housing Gasket
Thermostat Gasket
Oil Filter
Inlet Manifold Gasket
Exhaust Manifold Gasket
Valve Stem Oil Seals
Exhaust Manifold Studs
Exhaust Manifold Nuts
Autojoint AJ66 Sealant for
NGK Irridium Spark Plugs
MACHINE WORK
Block Boring/Honing
Block Decking
Crankshaft Polishing
Head Skimming
Head assembly - refitting valves with new stem oil seals, Reconditioning of oil pump etc
Uprated clutch
Basically all you need for 400bhp
All for the bargain price of £4400.
Cash on collection from Doncaster ideally.i could potentially pallet and send if it’s organised.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 15th Aug 2019 at 20:00
vts_gav
Sorry to bump did this ever sell?
Posted 19th Jan 2020 at 18:05
