Author Subject: Shell plus parts
fast_eddie
Anybody interested in a very good shell? Phase 2 diablo red.
All glass, boot, bonnet and doors fitted with a fully rust proofed and very well painted engine bay and front under side. All engine bay and arch seams dug out and rust proofed then re seamed with proper 3m sealant before re painting. Took me hours and hours. There is some slight mottling to the paint as its been stood under a tarp for a year and the is slight lacquer peel to the passenger door and roof. The rear tail gate has two rust marks on the bottom edge of the window and the front right underside jacking point has two 50p sized holes in it. Other that that its really tidy and comes with a decent reg plate. It currently has the passenger compartment ph3 wiring loom fitted loosely inside. I have everything else to finish a complete car from my 98 306 gti which i stripped to put into this shell. Bumper and front slam panel also present in body colour.
All parts plus postage or buyer arrange courier for larger parts:
Shell £300 REG S113 DEU
Engine complete £450 New rear crank seal
Box (replaced seals and clutch shaft bushes) Slight crunch at high revs into 2nd £75
Refurbished rear axle £75
Subframe-Shot blasted, seem welded, rust proofed and painted black £100
Flocked dash (has gone the way of the crazy paving in the heat of the garage) I will include all dash wiring and electrics and vents and glove box and airbag (both flocked) but they are not fitted £50
21mm torsion bars £150
Lightened flywheel (brand new not opened) £180
Shot blasted, seam welded, painted subframe £100
S16 deep bolstered interior red/black £200 including all interior plastics and headlining
New front arms £100
Nissens rad £40
Heater box with new matrix £40 (slight repair to one of the mounts but it was done well using a piece from a spare box)
Mint headlights £50
4 new toyos on ok wheels (have been sat a while) £120
Brand new solid rear mounts £160
Baker BM Gear Rods Brand new £20
Magnex system plus back box(Solid joint at centre pipe to cat) £100
Magnex back box £30
Carbon Cylindrical airbox £30
Plenty of other bits I've forgotten.
If someone wants everything as a job lot, I will chuck in everything else I have not listed like new cambelt kit, shockers, calipers, and other stuff I have lying around that was ready for the rebuild. Just make me an offer. I have too many projects now and something has to go.
It would be far easier to get hold of me via my mobile and texting is better as I work a lot.
Car will need collecting on a trailer and if you dont take the subframe, you will need to bring one. I have spare uprights and arms to make it rolling. Situated in Keighley, west Yorkshire.
Album:
http://s86.photobucket.com/user/bistro_boy/library/306
07931962229
more photos on Instagram watson.jonathan69
Posted 27th May 2019 at 22:42
pug_306
Sent you a text buddy :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 27th May 2019 at 20:58
fast_eddie
Got it cheers
Posted 27th May 2019 at 22:40
fast_eddie
Shell now on ebay https://www.ebay.co.uk/itm/113769076696
Posted 1st Jun 2019 at 20:29
Krists
Hi.
Is the engine available?
What is the engine code?
What is the engine condition?
Maybe some photo..
Posted 5th Jun 2019 at 14:16
barrym
Hi, are the 21mm torsion bars still available?
Black Rallye occassional toy
Posted 5th Jun 2019 at 21:01
fast_eddie
Updated thread after the shell and bits have been sold.
GTI6 Engine 130k Non Tapper Includes everything as it came out of my car £450
Box (replaced seals and clutch shaft bushes) Slight crunch at high revs into 2nd £50
S16 deep bolstered interior red/black £180 including all interior plastics and headlining
Nissens rad £40
Mint headlights £40
4 new toyos on ok wheels (have been sat a while) £100
Brand new solid rear mounts Baker BM £150
Citreon Xsara Rack £100
K and N filter (for standard housing) £20
Genuine Exaust fitting kit £20
Braided front brake lines £30
GTI6 Front brake calipers (need a refurCool £40
Valeo Clutch Kit New in box £50
Ocap 18mm Ball joints in box £50
Plastic Anti roll bar drop links in bags £40
Brembo Front disks in box £20
Brembo Rear disks in box £20
Brembo Rear pads £20
Genuine fuel filter £5
Might be easier to text me 07931962229
Everything either collection or plus postage.
Cheers,
Jon
Posted 9th Jun 2019 at 15:47
