Author Subject: Starting a engine for the first time in 4 years
Cjwatson27
Hi I’ve blind brought a car it’s currently doesn’t start the current owner believes it’s fuel. I was going to crank it over with the fuel pump relay disconnected to get some oil pressure. Anything else I should do before I try to start it ? Also is it worth using a engine flush before I service it. That’s if its not a dud I’ve bought ?
Posted 12th Feb 2019 at 21:33
blandy
Personally I’d squirt a tiny amount of oil in the bores., turn over with the plugs out as well so no load. Then plugs in and crank till oil pressure shows and then fire up.
Posted 12th Feb 2019 at 21:42
Cjwatson27
Cool makes sense, must give you a shout to pick that collar up for the satchshift, I’m at the where to I cut this big hole stage of fitment lol
Posted 12th Feb 2019 at 21:53
blandy
Yeah I’ve still got it in my car goes everywhere with me lol
Cutting the hole is a horrible job with the dash and engine in
Posted 12th Feb 2019 at 22:17
ale624
also, make sure the oil hasnt picked up any Water content from condensation, check the dipstick for any water above the oil line, or failing that drain the oil.
personally I would probably drain whatever (over) 4 year old s**te is in it before trying to turn it anyways, throw some cheapy tesco 10w40 in and then change it for some nicer stuff after its run for a little bit.
old oil tends to sludge up when sat, and the sludge will sink to the bottom.
Posted 14th Feb 2019 at 15:13
Cjwatson27
Struggling to start this :-( got fuel to the rail been though cleaned the plugs. It’s not even trying to start, what does the imboliser imboilise ? Found the earth to the body was missing and the earth to the fuse box on the passengers wing wasn’t connected. But still nothing. Any ideas going to try new plugs and order a compression tester. Has always any help or ideas appreciated
Posted 16th Feb 2019 at 19:17
Cjwatson27
Is there a light on the dash that should go out if the imboliser has gone off ? Been along time since I’ve been in a running driving 6
Posted 16th Feb 2019 at 19:53
mocinim
Where’s the v6 dude
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Feb 2019 at 21:45
Cjwatson27
Haven’t seen it in over a year I presume still at the garage. Gave up chasing him :-(
Posted 16th Feb 2019 at 21:50
ale624
quote:
[quote="Cjwatson27"]Struggling to start this :-( got fuel to the rail been though cleaned the plugs. It’s not even trying to start, what does the imboliser imboilise ? Found the earth to the body was missing and the earth to the fuse box on the passengers wing wasn’t connected. But still nothing. Any ideas going to try new plugs and order a compression tester. Has always any help or ideas appreciated
Are you getting spark while turning the engine over??
if you are try squirting some starter fluid at it and see if it will run off that.
not familiar with how the immobilisers work. Think it cuts fuel pump, from the 30 seconds i spent on google?
injectors might just be stuck closed if you are getting spark and fuel??
see if you can get it running with some starter fluid/brake clean Smile
Posted 16th Feb 2019 at 23:49
