Author Subject: Camshaft pulleys
stef306
I've been having a issue with the camshaft pulley slipping on the adjustment section. Despite cleaning and thread locking threads and seriously tightening the centre bolt after awhile it will slip and retard the cam. It's happened a few times even with sandy during mapping. The only way I've been able to stop this happening is having the cam adjustment up against the stops.
I've been thinking about changing to aftermarket pulleys as they have a different design.
Any input would be better
Stef
1990 205 gti6 supercharged
Posted 10th Dec 2018 at 10:09
devere
I thought the pulleys that spin round on the adjuster bolts were designed like that, so when fitted and tensioned the cam pulleys rotate round til they stop and is then done up?
It's been a long while since I worked with a standard pulley on them tho.
Posted 10th Dec 2018 at 16:15
stef306
Yes I'm aware of how they work but that isn't my issue, the pulley moved once assembled and running
Posted 10th Dec 2018 at 20:22
jeffers Forum Admin
Have you been tightening the centre bolt to the correct torque?
Team Running Engine again!
Team Negative Camber!
Posted 10th Dec 2018 at 22:06
stef306
Yes, new bolt and thread lock.
Posted 11th Dec 2018 at 07:35
pug_306
Are they standard cams buddy ?
1992 205 GTi6
205 Turbo 340bhp
Posted 11th Dec 2018 at 08:00
stef306
No newmans, sandy is stumped as much as I am
Posted 11th Dec 2018 at 15:03
