Author Subject: Ph1 Xsara VTS breaking
Ben_W
Formerly gpm
Guys,
I've bought a Ph1 98 R plate Xsara VTS which I'll be breaking. It should be being delivered over the weekend and I'll have more info then but it's a completely STD car. It starts, runs, drives, even has MOT until towards the end of September but the shell is knackered as the front suspension turrets are rotten apparently.
I'll say this now - the rack IS NOT available. Im keeping that. Everything else will be available. Ill put some prices, no idea if I'm close but will listen to offers as it all needs to go. Cars not even arrived and I'm getting earache....
Engine with 133k on it - £400
Gearbox - provisionally spoken for
Standard exhaust - provisionally spoken for
Rear beam £200
Front struts/springs £30
Brakes front £50
Brakes rear £25
Hubs £50 pair
Subframe £35
Wheels £50
Driveshafts £30
Not sure if there is anything else of interest/use on the shell. I'll start breaking early next week so will update then but get in touch if there is anything you are after.
Thanks
Posted 14th Aug 2018 at 21:46
Ben_W
Formerly gpm
Cars now arrived. Absolutely standard, even down to the radio.
Posted 17th Aug 2018 at 13:10
Kenan
Battery box cover?
Posted 17th Aug 2018 at 18:12
Ben_W
Formerly gpm
quote:
[quote="Kenan"]Battery box cover?
Need to check but I think that's the one thing I might not have
Posted 18th Aug 2018 at 09:26
alcon
was the parcel shelf and therefore speakers the same in the xsara as the 306? I may be needing a set of original rear speakers if that's the case.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 20th Aug 2018 at 13:37
Ben_W
Formerly gpm
I don't think so. There were no speakers in the parcel shelf, they were in the rear panels by the back seats.
Posted 20th Aug 2018 at 14:29
alcon
ah ok, thanks.
1999 Rallye (black)
Posted 20th Aug 2018 at 14:41
Carl GTI
Hi
I'm after the following parts if they're available:
Pipe that goes from air filter to inlet manifold
The air intake pipe (snorkel) that directs air from the front grille to the air filter
Possibly the N/S driveshaft, if it has ABS?
Posted 21st Aug 2018 at 20:43
Ben_W
Formerly gpm
Carl,
I have the snorkel and the driveshaft. The car does have ABS.
Posted 21st Aug 2018 at 20:50
Carl GTI
quote:
[quote="Ben_W"]Carl,
OK cheers. Let me check the driveshafts are the same, as yours as is an early PH1 and mines a later PH1 (year 2000)
Posted 22nd Aug 2018 at 19:57
Ben_W
Formerly gpm
Engine, gearbox, brakes (front and rear), airbox, cat, wheels all sold.
Rest still available. I will have everything else I want from.the car stripped by the end of the bank holiday and then the car will be going for scrap.
Bits still to come off/left are:
Fuel tank
Fuel pump
Subframe
Hubs
Rear beam
Front struts
Engine loom
Get in touch if you want anything. Don't want much for the bits, shame to see any go to waste
Posted 25th Aug 2018 at 22:12
Kenan
If the seatbelts are recoiling well and the same as the Rallye I'd take them please.
Posted 26th Aug 2018 at 17:59
Ben_W
Formerly gpm
Funny you should ask.....I'm just looking at taking those out.
I'll be in touch
Posted 26th Aug 2018 at 18:42
alcon
Is the spare wheel cage the same as a 306??
1999 Rallye (black)
Posted 26th Aug 2018 at 20:24
Ben_W
Formerly gpm
Certainly is bud and the hook mech is free (clearly been looked after this car as it's been greased and I've not had a single snapped bolt or stud!)
Posted 26th Aug 2018 at 21:00
alcon
Not too fussed about hook and bolt but interested in cage if it's not too crusty. Will take hook and bolt with cage as a complete package if all going to great scrap yard in the sky. Pm me price bud.
1999 Rallye (black)
Posted 26th Aug 2018 at 22:41
'll take the hook and bolt as mine has seized and needs sawing off.
Posted 27th Aug 2018 at 08:50
Do you also have the wheel brace to undo the spare wheel bolt?
Posted 27th Aug 2018 at 10:20
Ben_W
Formerly gpm
Ok, pretty much done with breaking it now. Unless anyone tells me they are after bits from it, the shells going for scrap as soon as I can arrange it....
Bits that might be of use (and can post at cost if required):
Bosch servo - £15
Bosch front wiper motor (which I'm fairly certain is the same as the 306) - £10
Heater matrix hoses - £10
Front seatbelts - £15 pair
Upper steering column - £10
Fuel pump - £20
Engine wiring loom - £50
Drive shafts - £30 pair
Front sub frame - £20
Front struts & springs - £20
Front wiper arms with what look to be relatively recent Bosch blades - £5
Fuel tank straps - £5
Can't think of anything else.......if unsold it's getting slung in the boot when it goes for scrap!
Posted 27th Aug 2018 at 15:18
RetroPug
If it has the same vac pump as the 306, there's a part on the spindle of it that I could do with.
It's in the bottom picture first post of this thread:
http://www.306gti6.com/forum/showthread.php?id=160773
I have a spare vac pump but it didn't come with that part on the end of the spindle.
Posted 27th Aug 2018 at 19:20
Ben_W
Formerly gpm
Sorry Luke, the engine is going complete
Posted 28th Aug 2018 at 06:18
Carl GTI
quote:
[quote="Ben_W"]Ok, pretty much done with breaking it now. Unless anyone tells me they are after bits from it, the shells going for scrap as soon as I can arrange it....
How much to post the air intake snorkel and front wiper arms? (if the springs in the arms are still in good condition)
Posted 28th Aug 2018 at 20:46
Ben_W
Formerly gpm
Carl, probably £5 at most....be a slightly bigger parcel due to the length of the arms.
Did you find out about the driveshaft?
Posted 28th Aug 2018 at 21:42
Carl GTI
quote:
[quote="Ben_W"]Carl, probably £5 at most....be a slightly bigger parcel due to the length of the arms.
I'll leave the driveshafts as there's conflicting part numbers on various websites. I'll take the snorkel and wiper arms if that's ok? If you accept Paypal, PM me and i'll pay, andI'll give you my postal address. Thanks
Posted 29th Aug 2018 at 20:51
pug_306
P1 vts are all the same shafts buddy
1992 205 GTi6
205 Turbo 340bhp
Posted 29th Aug 2018 at 21:50
