Author Subject: General checks
goldfish
Hi,
No he’s not in charge of HM Army.
I was thinking more in line of what to check when you’ve bought your first Gti6. I have done the timing belt and water pump, drop links, gear linkages and I have new rear discs and pads on order.
My car has fsh and isn’t due a service yet, so is there anything that needs checking that isn’t on a service?
Posted 21st Jul 2018 at 04:55
mocinim
I always change the gearbox and engine oil just to make sure there all good
Clean or replace the air filter
Beam mounts
Engine mounts etc
Fuel filter
Tyre condition
And check for leaks
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 21st Jul 2018 at 14:14
Cjwatson27
Rear pillars and front sills for rust
Posted 21st Jul 2018 at 18:41
Kenan
quote:
[quote="mocinim"]
Beam mounts
Is this a big job?
Posted 21st Jul 2018 at 19:00
mocinim
quote:
[quote="Kenan"]
quote:
[quote="mocinim"]
Beam mounts
Is this a big job?
No mate but its not simple with regards to time
Just take a look at them if the rubber is not perrished leave them
Thay will knock when there bolloxed
If there perrished get them changed bud
Posted 21st Jul 2018 at 23:30
goldfish
quote:
[quote="mocinim"]I always change the gearbox and engine oil just to make sure there all good
Any benefit from a K&N filter or isn’t it worth bothering?
Posted 28th Jul 2018 at 06:47
Ben_W
Formerly gpm
The standard airbox set up on these is very good.
All that happens with a K&N is you get an open filter, mounted low down. Plenty of risk of sucking in water and hydrolocking the engine. Perhaps less of a risk in Australia but hey. Only benefit, if you can call it one, is a bit more induction noise.
Posted 28th Jul 2018 at 07:10
goldfish
quote:
[quote="Ben_W"]The standard airbox set up on these is very good.
It’s winter at the moment and it’s been raining for far too long!
Ok, well that puts the price down a bit Thumbs up
Posted 28th Jul 2018 at 10:09
mocinim
Yes k&n original replacement type is good goes in the original airbox
As ben said above for the induction type i didnt like the lack of persormance at lower revs
Posted 28th Jul 2018 at 11:22
