Author Subject: 12v Boot Socket
silky
Has anyone fitted a 12v socket in the boot?
Had one in my golf and was perfect for plugging in coolbox etc on days out.
Am sure I've read somewhere that there is a yellow 'live' wire in the loom on one of the rear lights
Posted 25th Jun 2018 at 15:00
cully
yup off side light taped to the loom is a yellow wire it will become live if you put fuse 26 in Wink
i use this for battery charging when the car is stood up for a while
oh its 26 on a ph2 fuse box
Posted 25th Jun 2018 at 18:08
miki4
Cool, good to know. Thumbs up So that is a direct connection to the battery+ through fuse number 26 (Ph2 fusebox)? Do you now the wire gauge and what's its original use?
Posted 25th Jun 2018 at 19:41
silky
Great work Cully.
I take it I could buy a 12v socket. Use the yellow live straight to socket. Wire an earth from socket to a bolt in the rear somewhere. Put fuse (what amp?) in No 26 and it should be good to go?
Posted 25th Jun 2018 at 19:57
cully
yes it is a permanent 12v feed on mine, not sure if you move the shunt and it turns into a ign live?
yes bold a ground wire to the tin work and fit a socket
i recon it will supply 10-15amps
i have it fused at 10amps for my charger
Posted 25th Jun 2018 at 20:21
miki4
Thanks Thumbs up
Posted 25th Jun 2018 at 20:24
