Author Subject: T4 master cylinder question
foot
Ok so does anyone know if fitting a T4 master cylinder would work with running a set of HiSpec 4pots on the front and standard rear brakes?
Reason for this is my master cylinder is dead and I can’t seem to locate a replacement
Posted 29th Mar 2018 at 16:30
pug_306
I've had hispecs run on standard MC with no issues. I used a 25mm VW on 330mm brembos. I have a good standard master I can supply.
Regards
1992 205 GTi6
205 Turbo 340bhp
Posted 29th Mar 2018 at 16:59
foot
PM sent
Posted 29th Mar 2018 at 17:13
craig903
Fittings needed for a t4 are m12 Btw, when I ordered mine the website said m10.
208 GTI Owner
Posted 29th Mar 2018 at 21:42
jorg
the t4 m/c abs version has 2 ports which are M12 fittings as craig has said above. there is a 4 port non-abs version which has M10 fittings and it can be used without messing around with the shape of the fluid reservoir, just plug the holes of the other side.
7D0611019A
7D0611019B
306 2.1 S16 Tarmac Rally Car
Posted 30th Mar 2018 at 09:53
foot
Yeah I’m not all the worried about the way a T4 master cylinder fits what I’m more interested in is if it would work with the 4 pot calipers and what the peddle would be like
Posted 30th Mar 2018 at 12:36
jorg
the m/c should work fine with the calipers. the pedal should be firmer with less travel i believe.
Posted 31st Mar 2018 at 09:18
foot
Perfect thank you 👍🏻 I’ve managed to get hold of a standard second hand item but if that doesn’t work I’ll go with the T4 one. Thanks for your help
Posted 31st Mar 2018 at 12:12
demondriverdan
Bit late to the party but I run the VW one on mine and the pedal is pretty solid, that's with the 310mm kit. I used the 2 port version which required a bit of flexing the reservoir but nothing drastic
Rallye Race Car
Posted 3rd Apr 2018 at 10:30
IvayloPavlov
As far I understood the easiest way to delete the ABS is with 7D0611019A.Can I attach the original reservoir?
https://ibb.co/FYXzT9Q
Posted 4th Jun 2019 at 08:20
