https://www.buycarparts.co.uk/oen/1920v7
S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired
| Author | Subject: ICVs |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Which of these makes are any good?https://www.buycarparts.co.uk/oen/1920v7 ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
If I remember rightly the Marelli one is the one you want......________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
TomGC
Junior User Location: Donington Registered: 10 Nov 2012 Posts: 93 Status: Offline |
I can second that, put a Marelli one in mine a couple of years ago. |
Roon
Junior User Location: Chichester Registered: 06 Jan 2013 Posts: 91 Status: Offline |
Can buy them from Peugeot direct still but be prepared to pay around £140. Any cheap euros CPA gsf ones just don’t work tbh. |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Original Magneti Marelli part number is 230016079087. Just buy one from Germany, saves you some bucks. https://www.idealo.de/preisvergleich/Typ/8001063212302.html |
Is the OEM VDO as I seem to remember seeing one fitted originally?I replaced it a couple of years ago but can't remember the make. On Thursday morning in the cold weather and snow it started fine and ran while clearing off the snow. Soon after driving off it just would not tick-over then did for a few seconds and when I got home. On Friday it ran flawlessly so I'll get a Magneti Marelli one and keep in the car. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
miki4
OEM is Magneti Marelli. But there is also "VDO" written on the ICV body. Not sure why. |
