displaying posts 1 to 25 of 35
Author Subject: stud and nut conversion kit
foot
evening,
I'm looking into a stud and nut conversion kit and I'm aware you need M12 x 1.25 thread 80mm length to be able to run 10mm spacers.
I basically want to be able to run cyclones with normal road tyres but I also have a set of Pro race 1.2s that ill be running R888 or something similar on.
as a side note i now have a set of Hi-spec 4 pots fitted which is why i will need to run 10mm spacers while having the Cyclones fitted.
this does mean i will have to get two sets of nuts as cyclones need flat seat nuts and the 1.2s will need tapered
so basically i just wanted to confirm that this stud kit I'm looking at is all ok and then i will need to get some flat seat nuts
what are your thoughts of these?
Thanks
Tom
Posted 12th Jan 2018 at 22:05
That kit is amazing !!!!!!
Wil Declaudio bought a set off this guy for his 106 and runs 20mm spacers and they each have Allen/ centre if I remember to do them up First Time or remove ever ...rather than using two nuts locked together ...
The Wheel nuts are great quality also ...if I didn’t have some fitted already I’d be buying these ....PS suggest you loctite them also even though they have great shoulder stops Thumbs up
Posted 12th Jan 2018 at 22:39
Cjwatson27
Never seen them with that Allen key head in the middle makes it easy to check there tightness
Posted 12th Jan 2018 at 22:29
foot
Awesome I’ll get a set ordered up asap thanks guys
Posted 12th Jan 2018 at 22:33
RallyeRed
I have these and were happy with their quality.
You should use a high quality thread lock and be scrupulous over threads being clean etc etc.
Whilst I used the allen key to wind them in, I still double nutted them to tighten them up.
Being 80mm long you do feel the twist of a long stud and small allen key. I wound the double nuts much further down the stud before tightening. That said, they don't need to be crazy tight in the hub, it just seemed a more sympathetic way of doing it.
Posted 13th Jan 2018 at 07:25
foot
Oh really I thought you would have to do them up to the same torque setting you would for the wheels?
Anyone got any idea how tight they should be?
Thanks for the advise though I’ll still use the two nut method of installation
Posted 13th Jan 2018 at 09:39
you could just do them by hand, that will be more than tight enough if you use stud lock, you have nowhere near the clamping area you do with a nut.
Posted 13th Jan 2018 at 10:23
foot
Ah ok fair enough, would you still do the nuts up to 110nm once the wheel is fitted?
Posted 13th Jan 2018 at 11:04
no, 85.
no idea where you got 110!
Posted 13th Jan 2018 at 23:56
miki4
Depends on the wheels actually. Usually I tighten wheel bolts on steel wheels with 120 Nm. Many alloy wheels have something like 90 Nm in their data sheet.
Posted 14th Jan 2018 at 00:02
peugeot is a flat 85 whether its alloy or steel on any 4 stud vehicle since early 80's
Posted 14th Jan 2018 at 08:51
foot
I was given 110 by a main dealer garage I used for MOTs as a while back before I had a torque wrench I snapped a wheel bolt and had one of those moment where I realized I was being stupid and that I should get the correct tools for the job
Posted 14th Jan 2018 at 09:30
miki4
quote:
[quote="welshpug!"]peugeot is a flat 85 whether its alloy or steel on any 4 stud vehicle since early 80's
Okay, good to know.
Posted 14th Jan 2018 at 14:43
110 sounds like vw setting and they have 1.5 pitch threads.
Posted 14th Jan 2018 at 15:38
foot
Ah ok well I will change the way I do things from now on! Thanks for the info.
Posted 14th Jan 2018 at 15:49
eiei0
Sorry to dig up this but can you get nuts to suit this conversion that will also suit the standard Cyclones ??
Posted 12th May 2020 at 14:46
jeffers Forum Admin
Yes, although how easy they are to come by these days I’m not sure... google is ur friend! If I get five mins il have a look.
Team Running Engine again!
Team Negative Camber!
Posted 12th May 2020 at 20:50
eiei0
I remember when we had the Grp A 205 Rally car you could get really nice black flat nuts from Peugeot Sport in Coventry those were the days, They were expensive but super good quality
Posted 12th May 2020 at 21:13
still available from France
Posted 13th May 2020 at 08:45
Joep
Tidy Clicky
This is from the UK, right?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 14th May 2020 at 19:42
eiei0
Peugeot sport website is off line currently, is the eBay kit good quality does anyone know??
Posted 13th May 2020 at 12:03
Joep
I think the answer is in the second post of this thread Wink
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 13th May 2020 at 12:18
dcc
you get what you pay for.
I had this set fitted to my m3 without any issues, but i only fitted them once and never had the nuts off and on after first fitting, just checked the torque every so often.
a friend also had this kit fitted to his m3, with wheels on and off pretty much every weekend, the threads started to show fatigue, and it was noticeable how they were getting damaged. the stud can be easily bent out of shape if you're not careful. the nuts are pretty flawless, hard to cock those up really.
I have bought a kit for my 205, so I'm obviously not too worried about the quality, but if your car is a track/rally car and you will be using a spacer without a spigot ring then i'd suggest buying better quality. I don't imagine the tensile strength of the kit is anywhere near a standard bolt.
205 GTI
Xsara HDI
Posted 14th May 2020 at 14:59
t3ora
I have gone one step further,I have fitted ford studs,the ones that knock in from the back
On the back Ive drilled the thread out to 13mm and I’ve knock the studs in
On the front it’s a different story,because the Rear of the hub flange runs so close to The hub you can’t put the studs in (the stud heads sit 3mm or 4mm proud)
So way round is I got a machine shop to machine the back of the hub flange to make the wheel stud sit flush with the back of the hub flange,and yes there is enough meat on the hub flange
It must be the thickest hub flange on a road car
Then all I did was order some nuts to suit my alloy
Road/track car coming together slowly
Posted 14th May 2020 at 20:34
jeffers Forum Admin
https://www.ebay.co.uk/itm/173754890252
These any use?
Posted 14th May 2020 at 22:34
