Author Subject: Fuel gauge issues
mocinim
Q: Does the resister pin on the fuel guage/sender affect the dash gauge position
My fuel gauge works but starts just under the 1st quater
Or could it be the float stuck ???
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th Jan 2018 at 17:07
cully
unplug the plug at the fuel pump on the tank
short the 2 smaller pins loom side, not the larger fuel pump feed pins
turn on the ignition the fuel gauge should go 100%
turn ignition off
open the same pins turn ign on the gauge should show 0% + fuel light
Posted 9th Jan 2018 at 21:51
mocinim
Cully you da man cheers chap Smile
Posted 9th Jan 2018 at 21:54
cully
i have a fault on my daughters hdi the gauge never go's above 1/2 even when full, i believe that is the float resistor wiper worn out just waiting on a tank pump assembly to prov it Wink
mocinim
Mine was spot on until i took it apart for chassis paint and a spruce moose hopefully this will fix it
I had a 6 with the same issue
Will have a go in the morning me thinks
Good luck with yours keep us posted would be interested to know
Posted 9th Jan 2018 at 22:11
cully
did you remove and paint the earth points?
my just want to clean up the earth points
drivers footwel earth bolt and the one near the drivers seatbelt anchor point
oh and the big 3, battery to chassis to gearbox
Posted 9th Jan 2018 at 22:19
mocinim
No doing sections at a time back to front body wise all mechanicals where done first
Not rhe best way i know but as long as it all gets done properly
I only have the drive to work on
All electrics are carefully done it runs superbly feather light clutch drives like new all pug parts etc
A few teething issues and she has some sticky lifters but with a good run she goes quiet
Just need it back on the road really she doesnt like sitting around
Posted 9th Jan 2018 at 23:56
Cjwatson27
It could be that you have a odd number of 306s buy another one see if that helps
Posted 10th Jan 2018 at 07:34
mocinim
O yea this needs an update only two rallyes left
The 6 was sold so its quite even now its gone somewhere good so it wont be driven into a post LOL Guns
Posted 10th Jan 2018 at 14:02
Cjwatson27
It’s a slippery slope once you start selling them, before you know it you’ll have a vw camper on your drive lol
Posted 11th Jan 2018 at 09:54
mocinim
No chance
Only let the 6 go to concentrate on my black rallye
Its a break bleed and a new cat away from mot Smile
O and a fuel gauge reset issue lol
Posted 11th Jan 2018 at 19:27
Cjwatson27
https://www.ebay.co.uk/i/232634002515
Found this little gem for you to add to your fleet
Posted 17th Jan 2018 at 20:17
mocinim
Im guessing its pretty fubar it was up for 1400 last year i believe
And no i only do restore to factory settings atm
Perhaps just a little lowering Smile
Wheres your v6 ???? I want a go Smile
Posted 17th Jan 2018 at 23:47
mocinim
Wow just looked at the pics
This xsi encourages whole new levels of projectile vomiting
Who did that pink turd
And why have they not cleaned up there mess Guns
It should be burnt , filmed and posted as a warning to other pink turd creators
Posted 17th Jan 2018 at 23:53
Cjwatson27
I've had words looks like I'll be getting it back unfinished, just be glad to get it back it looking about rough now after being sat about for 18 months
Posted 18th Jan 2018 at 19:00
mocinim
Spit shine time dont give up on it
Whats left to do ???
Posted 18th Jan 2018 at 22:56
