Author Subject: Parts availability
I seem to be struggling to get a lot of tings these days, and i'm starting to think all the PAS racks are gone for our cars?
Anyone noticing the same?
Posted 29th Dec 2017 at 16:52
try having a 16v zx, or a 205!
Posted 29th Dec 2017 at 17:08
blandy
Haven’t got a xsara rack but I’ve got a moonstone gti6 w reg that I’m breaking. That has the standard rack in along with a set of clocks. I don’t know th pe mileage on them though as have had the engine removed
Posted 29th Dec 2017 at 17:19
It's all going that way now, don't forget the youngest of these cars are now coming up to 18 years old. Shock
Posted 29th Dec 2017 at 20:18
Blandy. Sounds good. If you could let me know about the clocks that woukd be great
Posted 30th Dec 2017 at 02:00
woody.
Yup a lot of stuff now NFP. My local dealer had to hunt around for an inlet manifold gasket the other day which I thought would be to hand
Posted 30th Dec 2017 at 18:11
fatlapit
I have said gasket
Posted 30th Dec 2017 at 21:09
fatlapit
And lots of vss
Some tps
And other stuff
Posted 30th Dec 2017 at 21:58
miki4
Yeah, inlet manifold gasket NFP. Little shock moment at the parts dealer three months ago when I needed to remount the inlet manifold during my LPG conversion. But you can get one from Elring as did I. Elring part number 176.930. According to their online catalog it fits following engines: LFY, RFS, RFT, RFV, RFY. And it fits better than the PTFE gasket I had before which started to flow and reduce the diameter of the inlet channels.
Posted 31st Dec 2017 at 13:42
fatlapit
Thermatec inlet gasket is awesome
Posted 31st Dec 2017 at 18:22
woody.
Good info, main dealer sourced one for me from another branch in the end
Posted 1st Jan 2018 at 11:05
miki4
I had the Thermatec one, bought from eBay brand new. It developed a small vacuum leak every now and then so I retightened the screws like three times before I took the manifold off. The material flows very badly under pressure and temperature. At least mine did. Had it on for 10 months and the gasket looked like a piece of crap and was not usable anymore. There must be a pic of it on a friend's phone.
Posted 2nd Jan 2018 at 00:27
fatlapit
Had it on my turbo 6 for nearly 5 years never had a problem. Had the tb gasket too
Posted 2nd Jan 2018 at 01:11
PAS rams haven't been available for years and years now!
Useful info on the inlet gasket thanks - I need one as I'm de-charging my car shortly.
Posted 2nd Jan 2018 at 08:46
quote:
[quote="fatlapit"]Had it on my turbo 6 for nearly 5 years never had a problem. Had the tb gasket too
is that Stan years where they actually only get used once in a blue moon? Razz
use the J4R or Mi16 gaskets, they are still available, or an aftermarket RS gasket.
Posted 2nd Jan 2018 at 09:27
Excuse me?
Yes, the current engine has now been in my '6' for 8 years and yes for some of that time it has been mothballed so to speak, however it was in heavy use during 2010, 2011, 2013, 2015 and 2016.
And by heavy use I mean trackdays and European trips etc.
Posted 2nd Jan 2018 at 14:12
Nose
I can possibly help with AFTERMARKET part numbers for bits if people get stuck, only on hard parts though like brakes, steering, suspension, wheel bearings, discs, pads, shoes, also STANDARD engine components /gaskets etc. I wouldn't be able to help with trim or body parts. Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 3rd Jan 2018 at 13:42
demondriverdan
Does anyone have a part number or link to an inlet manifold gasket then?
Rallye Race Car
Posted 3rd Jan 2018 at 14:21
pug_306
I use Payne gaskets never had a issue with them part number JD536
1992 205 GTi6
205 Turbo 340bhp
Posted 3rd Jan 2018 at 14:26
miki4
Elring part number 176.930 as in post #9 works fine for me. According EAN number is 4041248164181.
In fact any paper/cardboard gasket should do.
Posted 3rd Jan 2018 at 16:26
demondriverdan
Will give this one a go! https://www.onlinecarparts.co.uk/elring-986773.html
Rallye Race Car
Posted 3rd Jan 2018 at 17:19
fatlapit
I have a inlet gasket if any one wants it comes with free s**t
Posted 3rd Jan 2018 at 17:58
Nose
quote:
[quote="pug_306"]I use Payne gaskets never had a issue with them part number JD536
Yes Correct sir, I also have a REINZ number off 71-33666-00 if that helps anyone Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 4th Jan 2018 at 13:54
