Author Subject: Power steering pump bolt
woody.
Hi,
As above I'm after the following shouldered bolt, number 2 on the diagram. They are no further production from Pug and someone has sheared my one!
Thanks
Posted 29th Dec 2017 at 14:33
alcon
does anyone actually have number 6 fitted?.....I've never seen one.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 4th Jan 2018 at 13:17
woody.
Nope, not on mine. All about the weight saving Wink
Posted 4th Jan 2018 at 18:15
Yes Love it.
Apply back to black on mine the first Tuesday of each month.
  • Posted 4th Jan 2018 at 18:58
    alcon
    These stupid things are still available from Pug as well.....for under a tenner!! Meanwhile, major parts and nuts/bolts for practically everything are NFP!!
    1999 Rallye (black)
    Posted 4th Jan 2018 at 19:55
    alcon
    Would no. 70 in the diagram not work if you cut a bit off the end?.....looks to be the same bolt as the elusive no. 2 but a bit longer, and its still available.
    1999 Rallye (black)
    Posted 4th Jan 2018 at 19:53
    barrym
    Are you sure it's NFP? It's still available for my VIN but mine is a Rallye. M8x1.25 length 35mm. part number 6913 S9
    Black Rallye occassional toy
    Posted 4th Jan 2018 at 21:09
    woody.
    The no. 2 bolt has a shoulder that locates in the pump bracket, I've measured it up and will get a sleeve made and use a standard m8 cap screw roughly 37mm in length (not sure why pug didn't do this in the first place)
    But yeah NFP for no. 2 which is 4007 N7. 6913 S9 is the no.70 screw as you've said
    Posted 4th Jan 2018 at 21:24
    woody.
    Just to add some part numbers to the image in case anyone else needs them in future:
    And a better pic of the mounting (this is alternator but you can see the bracket for power steering as well)
    Posted 4th Jan 2018 at 21:36
    miki4
    The black plastic piece number 6 is only fitted to phase 2's afaik. Have seen them myself.
    No idea on the bolt, sorry.
    Posted 5th Jan 2018 at 00:38
    Mine made in early 1998 have the covers
    Posted 5th Feb 2018 at 10:27
    the bolt is shouldered so you can fit one partially, drop it through the slot and it will stay in place whilst you faff with the other 3 bolts, you then do it up and the shoulder fits in the hole nicely.
    Posted 5th Feb 2018 at 12:49
    woody.
    I've just sleeved that bolt instead, doesn't make it any harder to install tbh. For reference there's only 3 bolts that hold the power steering pump on, and the sleeve I used was 11.0 OD, clearance on the ID for an M8 Bolt so 8.10ish, and about 15.0ish in length.
    Posted 5th Feb 2018 at 18:36
