Author Subject: Converting to LHD
demondriverdan
Crazy thought of the weekend, is it possible to convert to LHD on a RHD shell? I think the main issues are steering column mounting points?
Rallye Race Car
Posted 3rd Dec 2017 at 12:42
devere
I helped a guy source the parts for a rally car that went from right to left hand drive. I don't think it was too bad for him to do. Obviously the steering rack also as well as dash etc. Then all the corresponding lhd bits like clutch cable.
Posted 3rd Dec 2017 at 12:55
demondriverdan
How did you move the brake servo etc.?
Rallye Race Car
Posted 3rd Dec 2017 at 12:57
I'd imagine you need a bulkhead cut and the pedal box assembly from a LHD car.
Posted 3rd Dec 2017 at 14:01
demondriverdan
At that point it's probably just easier to get an LHD shell!
Rallye Race Car
Posted 3rd Dec 2017 at 14:03
most likely, unless you already had a big weld in cage tied in everywhere, it doesn't appear to be that big a job as the panel isn't that big, drill out a ton of spotwelds, plug weld the new panel in place.
the pressing might be there for the steering column to pass through but not cut out, but the bulkhead is a different panel.
Posted 3rd Dec 2017 at 14:08
demondriverdan
The cage in my car is nothing special so would probably just get something new made.
I was mainly thinking of the balance benefit of both driver and engine not being on the same side of the car. I'm a big guy as it is, moving to LHD would offset the weight imbalance a bit.
Rallye Race Car
Posted 3rd Dec 2017 at 14:09
A diet would be far simpler and more cost effective.
Razz
Posted 3rd Dec 2017 at 14:29
demondriverdan
Haha Big grin Even if I was 20kg lighter it would be better Wink
Rallye Race Car
Posted 3rd Dec 2017 at 16:44
