Author Subject: Quote for driveshaft replacement
Carl GTI
My nearside ABS ring has come loose - local garage has quoted me £260 for a replacement, incl. labour & VAT. Am I being a tight bas**rd or is that a little overpriced?
Also, would it be wise to replace both sides at the same time?
Posted 6th Jul 2017 at 20:35
Cjwatson27
Speak to Ryan pug_306 he'll have some 2nd hand ones. Problem is most garages charge £70 a hour or at least they do round here so even small jobs soon add up, I paid £320 recently to have my car towed in to have a starter motor replaced. Which seem a bloody lot till you start breaking it down
Posted 6th Jul 2017 at 21:15
How much???
Balls to that! LOL look on carparts4less.com
Their not hard to do yourself just a bit messy,..
you'll need a hubnut socket 22mm if memory serves
A ball joint separator gearbox oil and crushable washer for gearbox plug
There should be a tutorial somewhere!
Posted 6th Jul 2017 at 21:19
pug_306
35mm for the shaft nut. I would use a good used genuine shaft as most of the pattern part ones don't last long.
1992 205 GTi6
205 Turbo 340bhp
Posted 6th Jul 2017 at 21:43
miki4
A crowbar should suffice. Smile A new gearbox washer is not always needed if you don't have one ready.
If you don't have a 35 mm socket, you could use a 36 as it's more common and line it with pieces of a feeler gauge.
Posted 7th Jul 2017 at 00:30
Thumbs up
Posted 7th Jul 2017 at 07:04
Only use the gearbox oil from Peugeot.
Posted 7th Jul 2017 at 07:18
wasnt an oem cv joint if the abs ring came off, but you can get replacements very cheaply anyway.
Posted 7th Jul 2017 at 10:12
gnrlee wrote:
How much???
hope it wasn't written by you...
Posted 7th Jul 2017 at 10:13
36mm socket is fine and doesn't need packing out. I've used a 36mm for years on umpteen 6's.
  • Posted 7th Jul 2017 at 11:48
    alcon
    35mm impact sockets are not hard to find....loads of them on ebay if you look.
    1999 GTi-6 (china blue)
    1999 Rallye (black)
    Posted 7th Jul 2017 at 14:13
