Author Subject: Fuel pressure regulator
mocinim
Hi gents which is best 3 or 4 bar / more suitable / or just the correct one
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 11th May 2017 at 20:10
deeturbo
I was under the impression that they were 4bar as standard.
Posted 11th May 2017 at 20:12
sageman
i recall reading the same somewhere
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 11th May 2017 at 21:08
pug_306
3bar is fine for standard engines buddy. I think late xsara vts was 3.5bar
1992 205 GTi6
205 Turbo 340bhp
Posted 11th May 2017 at 21:10
3 bar standard, without mapping its pointless adding more pressure.
Posted 11th May 2017 at 22:32
sergioiacobucci
What would be the best to go to if you are mapping? 3.5 or 4?
Phase 1 silver track car
335i daily
Posted 11th May 2017 at 22:35
Posted 11th May 2017 at 22:59
sergioiacobucci
Trying to work out if you're joking Dunno
335i daily
Posted 11th May 2017 at 23:15
not at all, basically unless youre running lots of boost there's no point running more fuel pressure.
if you need more fuel get bigger or more injectors.
Posted 12th May 2017 at 08:20
mocinim
Cheers guys appreciated
Posted 12th May 2017 at 10:12
russbez
it worth replacing these wee things?
they dont clog up or that?
My Rallye project thread
Posted 12th May 2017 at 10:27
no, very reliable, unlike all the adjustable tat.
Posted 12th May 2017 at 10:48
mocinim
Refurbing the rails x3 scrub down strip to steel repaint !!!
Posted 12th May 2017 at 11:43
miki4
I replaced mine at 160k miles as you could smell fuel on the vacuum hose. I guess they start leaking sometime.
As long as you don't run out of fuel flow / don't get your injectors to work on 100% during mapping I would just use the standard 3 bar FPR. The higher you go pressure-wise, the more you need to lower the time the injectors are powered to get the same amount of fuel into the engine. -> you lose time resolution.
Ryan, is it the same map with the 3.5 bar FPRs?
Posted 12th May 2017 at 17:39
pug_306
Hi buddy . They run completely different ecus ( multiplex ) injectors are different also. Hope your well ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 12th May 2017 at 17:51
yeah the phase2 xsara was quite a step forward in ecu's, twin lambda system as well as different injectors though mostly the same, they are much better on fuel than the older MM1AP10 ecu.
Posted 12th May 2017 at 18:14
miki4
Ah okay, interesting. Thanks for that info. I'm well, hope you too. Smile
Posted 13th May 2017 at 02:07
