Author Subject: Phase 3 Spoiler
sbolly
After a original phase 3 spoiler. Am I right in thinking they're made from a different material than the phase 2? Mine is currently looking very shabby and I want to repaint it. However I was told by a body shop it would be a useless exercise due to the material it's made out of?
'97 Platinum Silver GTI 6
Posted 7th May 2017 at 13:37
Joep
As far as I know, there is a phase 1 and 2, and a phase 3.
The phase 1 and 2 are one piece. The phase 3 is a two-piece version that is a bit longer.
I think a few members painted a phase 3 with good result.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 7th May 2017 at 16:18
miki4
Phase 3 is plastic afaik and should be no problem to paint. Mine is painted. Phase 2 is rubber and is trickier to paint. The paint can also crack due to flexing.
Posted 7th May 2017 at 17:48
sbolly
You confirmed my suspicions Thumbs up
Managed to get one sorted anyway, thanks for the replies
Posted 7th May 2017 at 18:02
mocinim
All will paint up well as long as you under coat with the correct stuff
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 7th May 2017 at 21:09
sageman
my ph3 has gone all pitted from the sun
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 7th May 2017 at 23:31
mocinim
Most do sand it down and use a plastic high build primer then paint
There is other paint type filler products you can get to smooth them out
Posted 8th May 2017 at 00:16
Rich E Forum Admin
Bear in mind the mounting is different between phase 2 and 3.
Phase 2 mounts through holes in the rear hatch glass whereas phase 3 doesn't so if you're going from 2 to 3 you'll need to drill a couple of extra holes in the hatch and plug the holes in the glass.
Posted 8th May 2017 at 12:24
