Author Subject: Replacement Exterior Trim
RobbieD
Hi all,
I'm looking to find replacement (new) rear sections of roof trim and also door window trim for my Rallye.
Has anyone done this before and got part numbers or any idea where to source them from?
Pics attached to make it easier to see what I mean!
Many thanks
RobbieD has attached the following image:
Posted 5th May 2017 at 08:36
RobbieD
Also the LH and RH versions of the door trims that fit here,
Posted 5th May 2017 at 08:38
itll be breakers or a dealer.
Posted 5th May 2017 at 09:21
mocinim
Pug 306 has a set !or did of roof gutter trims going for sale
as for exterior door window trims good luck if you get the part number let us know castor troy is also after some
I havent had time to look it all up but theres apossibility my parts gut may be able to find some with the part number
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 5th May 2017 at 09:28
Castor_Troy
Thumbs up
Posted 5th May 2017 at 10:09
alcon
9309 90 & 9310 82 for left & right door glass seals (both marked as NFP)
8319 E9 for roof trims (marked as available)
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 5th May 2017 at 10:21
RobbieD
Thanks a lot for the numbers, I called a couple of local dealers (oxfordshire area) who said none of the above number are available!
Hopefully Pug_306 has some decent ones but better not throw out my old ones just yet!
Posted 5th May 2017 at 12:00
alcon
What's wrong with the roof gutter ones you have? The window ones usually bubble up at the ends as the metal inside them rots.
1999 Rallye (black)
Posted 5th May 2017 at 12:06
RobbieD
I got one of the gutter trims off easily enough and in decent condition, as i think it had been removed before.
The other side wouldn't budge easily and kinked when it finally moved. For the sake of not very much money, it would have been nice to have a pair of new ones. But there we go!
As you say, window trims have started to bubble at the rear,
Posted 5th May 2017 at 12:20
Nose
I was lucky then, bought 2 new door glass seals last year i think it was, maybe a bit longer, direct from Pug Thumbs up The roof ones i'd agree with the scrap yard, shouldn't be a problem i wouldn't have thought.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 8th May 2017 at 20:25
