displaying posts 26 to 47 of 47
Pages (2): 1 [2]
Author Subject: Track day Exhaust for low boost 6
simonmanchester
Its quite a decent sized backbox, 400mm long but it's quite wide (I'd say around 400mm). I'll get a pic up shortly.
Simon
Posted 2nd May 2017 at 20:59
simonmanchester
Correction, it's about 250mm wide...
Simon
Posted 3rd May 2017 at 08:00
simonmanchester
Bonus pic...
Simon
Posted 3rd May 2017 at 07:57
simonmanchester
Edited links for pictures.
I've ordered the acoustafil so hopefully that should make it quiet enough.
Simon
Posted 3rd May 2017 at 08:03
What diameter is the pipe in the centre? It looks pretty small..
Posted 4th May 2017 at 21:10
simonmanchester
2" - not ideal I guess.
Acoustafil still hasn't arrived, so no updates yet. Itching to get it done so I can get back on the track Smile
Simon
Posted 8th May 2017 at 07:49
3rd time lucky
Bro! Low boost should be running 2.5" all the way through.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 8th May 2017 at 08:31
3rd time lucky
Even the standard exhaust is 2 1/4" iirc.
BLACK RALLYE - Sold
Posted 8th May 2017 at 08:32
simonmanchester
Yea it's probably on the small side but it didn't seem to affect the performance, still quick. Would a larger diameter exhaust be noisier though?
Simon
Posted 9th May 2017 at 08:21
manthos
Post #35
I have a full 2.5" jetex system I'm willing to sell sitting in the garage if you're interested that will shut it up perfectly
Team SUPERCHARGED
Old Project thread
Posted 9th May 2017 at 09:32
Post #36
standard exhaust tapered from 2.5 at the engine to 2" at the tailpipe.
Posted 9th May 2017 at 12:01
simonmanchester
Post #37
I've pm'd you manthos :-)
Simon
Posted 9th May 2017 at 18:23
simonmanchester
Post #38
Thank you to manthos - I now have a Jetex fitted, and its definitely a lot quieter. I think the performance is slightly better so definitely having the 2.5" bore helps with the low boost charger. I just need to get it to an exhaust fitter to alter it slightly as its knocking underneath a bit (struggled to fit it whilst lying underneath my trailer), then I can book another session on the track and find out for sure Smile
Thanks everyone for the advice - much appreciated!
Simon
Posted 16th May 2017 at 10:44
3rd time lucky
Post #39
Awesome Thumbs up
BLACK RALLYE - Sold
Posted 16th May 2017 at 10:48
simonmanchester
Post #40
Slight issue, but just want to make sure I'm not being a dumb ass. Its knocking underneath the car, so I took it to an exhaust place and he had a look. He said the system seems to be too far forward towards the front of the car, and he let me have a look whilst it was on the ramps.
It does seem that all the brackets, bends etc, are about 2" out of place. He suggested I take it to an exhaust centre that creates stainless systems and have a 2" section welded into the cat section to push the system backwards into the correct place.
When fitting the Jetex, I had to remove the existing decat pipe as it had an incorrect flange (I think thats what the joint is called) for mating up to the Jetex system, so I used the spare cat I had in the garage and knocked the internals out (effectively making it a decat system). I'm not sure, but i'm guessing the decat I had before was longer than the original cat on the original system.
Whats my options? Get a new decat pipe made? or modify the cat i have to be longer? Is there anything i can do to lengthen the cat without having to remove it from the car?
Simon
Posted 24th May 2017 at 14:31
3rd time lucky
Post #41
Any pics of the previous decat flange, current joint between cat and centre pipe?
BLACK RALLYE - Sold
Posted 24th May 2017 at 16:42
RetroPug
Post #42
Either get the correct flange welded onto the decat, or get extra length welded onto the end of what is currently fitted.
Posted 24th May 2017 at 20:27
barrym
Post #43
Not sure what you have going wrong there but my Jetex fitted perfect first time
Black Rallye occassional toy
Posted 24th May 2017 at 20:49
3rd time lucky
Post #44
I can't imagine a hollowed out cat is good for air flow, although I'm sure it's been done time and time before. Your better off with the proper decat but with the correct flange fitted Thumbs up
BLACK RALLYE - Sold
Posted 25th May 2017 at 07:13
Post #45
it wont hurt it, less restriction than a cat but messes up the pulse tuning less than a straight pipe.
Posted 25th May 2017 at 10:56
Post #46
It's charged now, not sure it matters as much as on n/a or before a turbo. Best scavenge possible is the way to go - get heat away as quickly as you can
Posted 25th May 2017 at 20:50
simonmanchester
Post #47
Just realised I didn't update this thread. I ended up getting a spookx decat and a trusted garage to fit it all properly, no knocking and all aligns up properly. Took it to donington this week for a trackday and didn't get flagged. Thanks everyone :-)
Simon
Posted 22nd Oct 2017 at 13:10
Pages (2): 1 [2]
