Author Subject: CV joint differences?
RallyeRed
Hopefully I'm not being too thick here..
Are there differences in the CV joints (inner and outer) between ph1, ph2 etc?
The driveshaft guys sorting out my wide track stuff say there are, and some are NLA?
I must confess I didn't realise there were differences..
These are abs ones btw.
Thanks
Iain
Posted 11th Apr 2017 at 11:55
none whatsoever as far as I have cone across.
they're all abs hollow shaft type, same as the turbo diesels and xsi's.
lower spec non abs cars may have solid bar and smaller cv with same hub and gearbox spline but they are not common
Posted 11th Apr 2017 at 12:34
Yeah, my early 1.4 had small solid shafts with a spider type outer CV, shouldn't really be relevant for anything XU though.
Posted 11th Apr 2017 at 13:36
RallyeRed
Thanks for your prompt replies fellas. If you two guys don't know of any differences then that's as good as gospel for me.
I'll get back to the driveshaft company.
Iain
Posted 11th Apr 2017 at 14:23
have you tried satchell engineering?
Posted 11th Apr 2017 at 14:29
RallyeRed
Haven't done, no.
Is this something they retail?
I'm waiting on the driveshaft company coming back to me.
Obviously getting hold of the outer joints isn't difficult anyway, but they're also saying inner are NLA, so just looking into reconditioning as an option.
Posted 11th Apr 2017 at 23:42
I've never seen inners available separately but there are companies making shafts so they are being made!
yes satchell can make shafts.
Posted 12th Apr 2017 at 07:26
