Author Subject: LB Supercharger kit
ravemercer
Selling on behalf of existing member the kit was brought but never fitted as there was change of plans £1500 for the fitting kit and all the extra parts not normally included there's almost every part needed to get running. New this lot would set you back about 4K
The charger has done less than 9K
Includes
Rotrex fitting kit and throttle body
Rotrex Superchager C30-94
Rotrex oil cooler header tank and pipe work
Low boost injectors Bosch 440cc
Mapped Ecu with latest revision
lynx inlet manifold
O.e inlet manifold gasket
Lowboost intercooler setup
Auto tensioner with alloy pulley
2x Spal slimline fans (Brand new)
Pas relocating kit
Air filter (Could do with a new one!)
Wire for extending sensor plugs and fans
90 Elbow for pas low pressure pipe 3/4"
Icv filter 19MM NECK ID/51MM FILTER OD/38MM
Extra needed to get running
Alternator belt 6PK1560
Pas rubber pipe 3/4" 1m
High pressure Pas pipe
Spark plugs NGK BKR7EIX x4
Engine oil
Charger fluid
For an extra £200 I could supply 6 ltrs royal purple, o.e Engine oil filter, sump washer, 1ltr Rotrex sx150 charger fluid and Rotrex magnetic oil filter.
Posted 6th Apr 2017 at 19:15
Dexter1002
how much for the royal purple on its own?
Auto electrician for Wessex DAF
Posted 15th Mar 2017 at 22:09
ravemercer
At the moment not selling separate sorry
Posted 15th Mar 2017 at 22:11
Dexter1002
okay let me know if it doesn't go with the rest and i will take it.
Posted 15th Mar 2017 at 22:13
Stecromp83
Pm'd you mate
Posted 16th Mar 2017 at 09:13
fatlapit
You can get royal purple from here
http://www.aas-exhausts.co.uk/
Posted 16th Mar 2017 at 12:36
Dexter1002
Ideal thanks!
Posted 16th Mar 2017 at 13:17
easypug
BAD SELLER
Interested, any movement on price? PM me if you wish?
Posted 17th Mar 2017 at 00:19
ravemercer
Currently sold pending deposit
Posted 17th Mar 2017 at 21:35
ravemercer
Back up for sale
Posted 6th Apr 2017 at 19:14
pug_306
Hi buddy would you do £1500 with the oils?
1992 205 GTi6
205 Turbo 340bhp
Posted 6th Apr 2017 at 19:49
ravemercer
Sold
Posted 11th Apr 2017 at 17:13
