Author Subject: Dash Headlight Tilt
oliverharveyuk@hotmail.co.uk
I'm having an issue where if I use the interior headlight tilt switch in the dash to the right of the steering wheel my nearside headlight moves up and down accordingly but my offside does not move at all, anybody have any ideas?
98 Blaze 6 - Current
Posted 13th Feb 2017 at 10:11
check its plugged in.
Posted 13th Feb 2017 at 10:37
fatlapit
check its the correct headlight
Posted 13th Feb 2017 at 15:24
mocinim
Check the motor is in and works
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 13th Feb 2017 at 16:29
RetroPug
As above, motor can be on the back of the light but not fitted properly.
Posted 13th Feb 2017 at 21:40
scotzman
I had this once, connections in the plug had become a little green.
Posted 14th Feb 2017 at 09:30
So I have taken the headlight out and replaced the motor, its all plugged in nice and tight but as you say scotzman my connections are very green! Which is probably the reason its not working, anyone recomend stuff to clean and a way to clean very small female connections? No room for a screwdriver or sandpaper... Tried contact cleaner but still looks green...
Posted 27th Feb 2017 at 13:15
mik
Try some WD40 and plug and unplug it a few times to scrape the contact area clean.
Cherry Rallye SOLD
Posted 27th Feb 2017 at 14:30
mocinim
Wd40 leave to soak for an hour or two then electrical cleaning spray to remove residue and the crap that remains
cotton bud tips to agitate the green to remove with wd40
Clean and repeat
For any chunky electrical contacts fine grain lynishing paper of very fine dimond files
Posted 27th Feb 2017 at 15:27
Thanks I'll give that a go tonight Smile
Posted 27th Feb 2017 at 15:39
Wire tooth brush type tool are always good for this sort of thing!
Find them in pound shops quite often!
Posted 27th Feb 2017 at 18:20
Cherry Buell
I have this problem with my car but the opposite way around, the N/S being the culprit. Connections look good. Swapped the motors and still no joy. The problem presented itself with the N/S jumping up and down and then quitting. It is clicked in to the reflector properly. Could it be the roller switch? What fuse guards this circuit?
Posted 6th Mar 2017 at 02:41
Mine did turn out to be green connectors, if you have a ph3 if you take the rubber sleeve off the connector you can then clip off the yellow plastic by pulling it up which exposes the connections so you can have a better look and a better clean Smile
Posted 6th Mar 2017 at 10:04
