Author Subject: Central locking IR sensor going bad?
ale624
Hi Guys,
My central locking is having a weird issue at the moment. it seems to be that when it is cold, and dark. my IR central locking stops working...
try to lock or unlock my car at night and nothing. hold the key button down, press it rapidly while waving around the window like a lunatic. nothing.
try it in the day time, works fine. past about 8pm and it stops working again... what the hell?
i should note, it works fine when i get home from work at about half 6, and its pretty dark then.
i recently replaced the key battery, so its not that, and i can see the little IR LED lighting up in a camera.
anyone encountered this before?
can i just chuck a sensor at it? or does it have to be keyed to the car? Dunno
Posted 11th Jan 2017 at 23:18
ale624
anyone got any clue?
Posted 12th Jan 2017 at 21:15
Kenan
Hi, I don't know what the fault is but believe that the sensor is linked to the key and can't be coded so you have to change the sensor and key together from another car.
Posted 12th Jan 2017 at 21:30
ale624
ah, that kind of sucks.
its super weird. it has worked fine today...
Posted 12th Jan 2017 at 21:32
You can make any IR key work.
Posted 12th Jan 2017 at 22:17
ale624
any specifics on this?
is it plug and play? there any docs for the locking systems on these?
Posted 12th Jan 2017 at 23:28
mocinim
Ir key will work but the immobiliser chip wont and i believe there coded to the reciver though the locking ecu
Not sure the dark will give you issues
Light frequencies get less interference at night
Could be condensation on the reciver plastic ??? Clean it and see !!
Mine works better on hot sunny days
Having said it usually does what the hell it wants when it wants
Thats why they they changed them for radio emitters
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 12th Jan 2017 at 23:38
mocinim
?? You are pointing it at it ???
Posted 12th Jan 2017 at 23:39
ale624
yes, of course! I'm not that stupid! LOL
OK, i might have a fiddle with it on the weekend.
condensation is a possibility.
dont normally get much on the windows though.
Cheers! Thumbs up
Posted 12th Jan 2017 at 23:50
how many keys have you got?
Posted 13th Jan 2017 at 01:49
cully
changed mine to RF with some after market fobs and intergrated the std alarm to activate/deactivate at the same time as deadlocking
Posted 13th Jan 2017 at 14:35
ale624
got one IR key and one normal turn key.
Posted 13th Jan 2017 at 21:02
ale624
eh. i want to keep the rallye as stock as i can, bar a few things. IR fobs give the car a sense of (albeit annoying) character
Posted 13th Jan 2017 at 21:03
