copied and pasted from the original ad:
quickshift with a new higher base, making it shorter and closer to the steering wheel, without loosing any of the correct/mechanic feel.
In the lower end, the original plastic bush was replaced by two roller bearings, eliminating any possible material wear.
It uses a constella quickshift with stronger bearings. Gearknob is a Sparco Carlos Sainz edition.
holes have been drilled in the side of the base to attach a brake bias valve, this can be included in the sale at extra cost. includes a bike lever so you can still use the 6 speed reverse cable.
Looking for £120 for just the gearstick, if you want the ap racing bias valve included i will do both for £180. Both prices are including delivery to mainland UK.
if you have any questions please just ask and i will do my best to answer
Geoff
306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956
jorg
