Did you have a fitting for the vacuum hose that sits further down the standard inlet manifold?
Phase 1 silver track car335i daily
displaying posts 26 to 41 of 41
Pages (2): 1 [2]
| Author | Subject: Mounting throttle bodies and setup |
sergioiacobucci
Senior User Location: High Wycombe Registered: 27 Nov 2007 Posts: 526 Status: Offline |
Are you running a 205 rad there? I am getting the 118mm too so looks pretty tight!Did you have a fitting for the vacuum hose that sits further down the standard inlet manifold? ________________________________________ Phase 1 silver track car335i daily |
my inlet looks a bit shorter, and yes im in TH's not tb but still ran 90mm trumpets and a 125mm filter.plenty of room as in nothing is touching ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
blandy
jorg
Senior User Location: Wallasey Registered: 10 Jun 2007 Posts: 816 Status: Offline |
my setup with Satchell inlet and 118mm bodies![]() ![]() ________________________________________ 306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956 |
sergioiacobucci
Thanks Blandy! Look like they were covered quite a bit but I think I am going to make a scoop up.Jorg you look like you have so much more space! Love the back powder coated inlet, may have to copy that...did you run 8 injectors? ________________________________________ Phase 1 silver track car335i daily |
I had shorter Jenveys with my standard engine & had the same air filter as in this picture which has shorter jenveys supplied ....Tony Palfrey from Maxi Motorsport is amazing & does sell at reasonable prices ...https://www.maximotorsport.com/products.php?directory=products/Satchell%20Engineering/Throttle%20Body%20Kits/XU%20kit |
sergioiacobucci
Day666 wrote: I had shorter Jenveys with my standard engine & had the same air filter as in this picture which has shorter jenveys supplied ....Tony Palfrey from Maxi Motorsport is amazing & does sell at reasonable prices ... https://www.maximotorsport.com/products.php?directory=products/Satchell%20Engineering/Throttle%20Body%20Kits/XU%20kit Thanks Damien. So they are not 118mm in Jorg's picture? ________________________________________ Phase 1 silver track car335i daily |
jorg
my bodies are 118mm but i have the same trumpets from the link Damien posted. can't remember what size the filter is, will have to look. no clearance issues as you can see and yes it is setup for 8 injectors but i am undecided what to use at the moment.________________________________________ 306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956 |
sergioiacobucci
Post #35
jorg wrote: my bodies are 118mm but i have the same trumpets from the link Damien posted. can't remember what size the filter is, will have to look. no clearance issues as you can see and yes it is setup for 8 injectors but i am undecided what to use at the moment. Thanks Jorg. Ok i think the jenvey trumpets are quite a bit longer, still looks like it should be ok. I think ill cut the slam panel out and create a scoop ________________________________________ Phase 1 silver track car335i daily |
Post #36
no need to cut the panel, you can go under it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
blandy
Post #37
My manifold I have in my 205 is much more the one in Jorgs set up. My one in the pic was around 4years ago odd though as was a satchell inlet as miles did all the work but is much longer than any other I've seen |
sergioiacobucci
Post #38
blandy wrote: My manifold I have in my 205 is much more the one in Jorgs set up. My one in the pic was around 4years ago odd though as was a satchell inlet as miles did all the work but is much longer than any other I've seen OK that might make sense then. WP - I'll see what looks tidy and go with that. I have a load of other questions for you guys to see where you routed breather hoses etc or what you did with them. ________________________________________ Phase 1 silver track car335i daily |
grantpipe
Junior User Location: golspie Registered: 01 Dec 2014 Posts: 86 Status: Offline |
Post #39
im using a jenvey inlet atm but want to change to satchell,does anyone know what they cost??also dunno if it was mentioned about relocating the power steering pump aswell to be able to fit a filter and backing plate |
Post #40
£180 plus vat with an exchange inlet IIRC. around the same as a Jenvey inlet, but better.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
sergioiacobucci
Post #41
grantpipe wrote: also dunno if it was mentioned about relocating the power steering pump aswell to be able to fit a filter and backing plate I heard you can squeeze it on without moving the PAS with a longer/satchell type inlet ________________________________________ Phase 1 silver track car335i daily |
Pages (2): 1 [2]
