Author Subject: Won't start...
thewho07
Parked my 6 up a few weeks ago went to it this morning it won't fire up. Turning over fine etc. Thinking it's the immobiliser maybe as central locking isn't working but was working when I left it a few weeks back. Key buttons aren't working (they were working when I left it) and when I unlock with the key in the door only that door unlocks, not both. Any ideas?
Posted 9th Jan 2017 at 20:53
thewho07
Just checked fuses and no6 fuse was the problem. I replaced it with a new one but it's immediately fused again. Hmmm?
Posted 18th Dec 2016 at 12:28
check the CL fuse, with that popped it wont disarm the alarm which in turn wont allow the immobiliser to disarm.
Posted 18th Dec 2016 at 12:33
obviously a short on that circuit, find out what it feeds and start unplugging stuff till the fault goes away.
Posted 18th Dec 2016 at 12:34
Yes, it's that same 5A fuse which runs the interior lights, CL and immobiliser. Probably a short in one of the doors wiring which is causing the fuse to blow.
Posted 19th Dec 2016 at 17:33
thewho07
Ok thanks for the help! I'm useless with electrics! I'll have a look at the door wiring first
Posted 19th Dec 2016 at 17:36
mocinim
Id be inclined to check the light first check the switch
Most likely the doors but you never knowSmile
Water through the roof ???
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 20th Dec 2016 at 11:29
My rear wiper leaked and shorted the fuse to the locking system and ignition so i'd defo say a fuse!
then might be worth having a look at that rear wiper motor relay for corrosion or wetness!
Posted 20th Dec 2016 at 11:45
thewho07
Right guys I've not had time to have a look for the problem yet but have noticed a water leak up by the passenger side ultrasonics sensor. The roof lining is damp in the corner too. Could this cause the shorting of that circuit? Hopefully have time at the weekend to investigate fully.
Thanks
Posted 22nd Dec 2016 at 09:38
It could well do as the interior lights are on that circuit.
Posted 22nd Dec 2016 at 09:46
thewho07
Thanks Stan. Had a little time to look at this today. There is water getting in, I presume from the aerial. The two lights were plugged in and are working fine however, the orange one wasn't plugged in. What is this? With the three plugs disconnected plus the left and right door looms, the fuse is still blowing. What would you guys look at now?
Thanks in advance - I'm clueless with electrics! Dunno
Its the 5A circled in white;
20mb image hosting
Posted 9th Jan 2017 at 16:58
mocinim
Water in roof Thumbs up
Looks like you have water in your remote locking sensor
Get out the old hair dryer and make sure all is crispy dry then try again
Any idea on fuse number
Is your car 2000 onwards
F4 5amp fuses are (if im guessing your panel correctly)
Pas airbag neutralisation , instrument panel,passenger compartment protection unit coolant temp unit and auto locking ??
Or F6 5amp,, clock and outside temp display , passenger compartment unit ,instrument panel, luggage compartment lighting
Posted 9th Jan 2017 at 18:59
mocinim
Guessing F6 luggage compartment lighting ????
Posted 9th Jan 2017 at 19:01
thewho07
Year is November 1999 mate.
According to FAQ for phase3;
6 5A Instrument panel - Passenger compartment protection unit - Alarm light - Luggague compartment lighting -Rear courtesy light
Posted 9th Jan 2017 at 19:17
thewho07
But even with this unplugged its still blowing the fuse... Dunno
Posted 9th Jan 2017 at 19:42
mocinim
Do all of the lights work
Posted 9th Jan 2017 at 20:51
mocinim
Is there water in it e.g the loom connection side not the sensor side
It doesnt need to be plugged in for the wire to contain water and short the fuse
Posted 9th Jan 2017 at 20:54
thewho07
No water anywhere I can see... Started the car today and had heater on for good 20 mins to dry things out. Popped the 5A fuse back in and everything was normal again - central locking worked, instrument panel worked fine, clock/outside temp working etc. Turned the car off then went to check the fuse - it had fused again. So I presume I'd dried something out with the heater on which sorted the short circuit. Really p**sing me off now don't know where else I can look!
Posted 12th Jan 2017 at 22:37
mocinim
Could be Just the wiring its self
The fan fault on the white was this buried deep it was Sad
mocinim has attached the following image:
Posted 12th Jan 2017 at 23:20
