Author Subject: Air tools for de-rusting
alcon
A question for all you project guys who have tackled the underside of your car......have any of you used air tools for de-rusting & paint /underseal removal? If so, what did you use and what attachments are best?
I've got a decent sized compressor now putting out 14cfm of air so was looking at getting an die grinder or something and fitting wire wheels as used in a regular power drill.
Thoughts?
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 6th Dec 2016 at 10:53
clen666
These are quite useful in an angle grinder.
Team 'unintentional rat look'
Posted 6th Dec 2016 at 13:19
alcon
I like the look of them but I'd need something with a centre spindle in order to mount in the air grinder I was hoping to use. I have a mains powered angle grinder that would take these type of discs but its quite heavy when working above your head for hours at a time!
(maybe I've just got gay wrists!)
1999 Rallye (black)
Posted 6th Dec 2016 at 13:32
turn it over.
Posted 6th Dec 2016 at 13:39
mocinim
These are really good and also come with centre spindle for drill attachment
I used a mixture of cheap wire brush attachments box of 24 for 12bucks ebay then one of these for final clearence deox gel and acid for the pitting
And then a shot blaster with captive bag for the really stubborn parts bit messy but not as bad as i thought it would be
Mainly used a drill n grinder easier for access
Also brought a drill extension cable really helpful for behind the beam stop rubbers and other tight areas
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Dec 2016 at 16:48
mocinim
Yes very wimpy gayness man up u puff Smile
Posted 6th Dec 2016 at 16:50
pugheaven
Heat gun and a scraper is best as you won't take of the primer or galvinised plating that you will take off with a wire brush.
Plus a lot less mess
Posted 12th Dec 2016 at 16:42
gbryn
You need one of these in your life!
Ideal for nooks and crannies..
Posted 12th Dec 2016 at 20:49
