Author Subject: Strut Brace Bolts
oliverharveyuk@hotmail.co.uk
I've just got a 2nd hand omp strut brace off ebay and looking through the forums you need longer than standard bolts to fit it. Seems you need m8 x 20mm so are these what I need? Also do I still use the standard washers?
http://www.screwfix.com/p/easyfix-bzp-set-screws-m8-x-20mm-100-pack/12685
98 Blaze 6 - Current
Posted 16th Nov 2016 at 15:05
yeah you can do mate! all they do is hold the suspension leg to the chassis
as long as the bolt get enough purchase through the top hat plate it's all good!
the washers will just stop you marking up the plate from the strut brace! Wink
Posted 16th Nov 2016 at 16:31
mocinim
Be careful on length they only need to be longer by a few mm obviously the same mm as the plate on the brace
To long and you will risk grinding the top spring cup
My white rallye came to me with this issue
It destroyed the mount thread and all needs replacing
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Nov 2016 at 16:56
Ah okay ill take one off and measure it then the plate width to check I won't be overdoing it with 20mm, I was more worried about strength and stuff don't want the bolt snapping on me...
Posted 16th Nov 2016 at 17:09
8.8 is fine, standard bolts are 8.8 iirc.
Posted 16th Nov 2016 at 17:38
6923 g6 is a 20mm long bolt with a captive wsher btw.
Posted 16th Nov 2016 at 17:44
That sounds perfect then, this is probably a stupid question but to buy that bolt using that part no. do I go through a Peugeot dealer?
Posted 16th Nov 2016 at 18:03
just googling the part no brings them up here's a place you could order them from online!
Posted 16th Nov 2016 at 18:20
mocinim
Yep 8.8 and 20Nm torque only !!! no need to tighten further even though they will easily they will thread out if you push it
Posted 16th Nov 2016 at 18:30
mik
The OE 16mm bolts on my top mounts were 10.9, but Phillipm said in this thread that the difference would not matter in this application.
The 6923 G6 20mm bolt is listed as a water pump bolt and I got some from a Pug dealer
From my project thread:
mik wrote:
I got the new slightly-longer bolts from Peugeot today (6923 G6, M8 x 125 x 20mm), and couldn't resist getting the strut brace installed straight away.
Cherry Rallye SOLD
Posted 16th Nov 2016 at 18:52
mocinim
Those 10.9 are probably from the subframe cup there almost exactly the same but 10.9 instead of 8.8
Posted 16th Nov 2016 at 19:00
Thanks for your help lads, just ordered the bolts and a new oil cap cause mine was leaking even though it's barely 2 months old... should be able to get the brace on this weekend, happy days!! Big grin
Posted 17th Nov 2016 at 13:12
Thanks for the help lads, just fitted the brace with the new bolts and very happy with the outcome Smile
Posted 19th Nov 2016 at 16:07
