Author Subject: What is this light?
sergioiacobucci
This came on on my drive home. Any ideas?
Sorry its a s**t picture
Phase 1 silver track car
335i daily
Posted 24th Oct 2016 at 22:39
superchargedblack1997gti6
brake fluid low if it's up top I think?
Posted 24th Oct 2016 at 23:03
sergioiacobucci
To be clear it looks like this up close just in a different position to thus pic
335i daily
Abs warning light!
Posted 24th Oct 2016 at 23:07
sergioiacobucci
superchargedblack1997gti6 wrote:
Abs warning light!
Does it even have abs? Ha
335i daily
Posted 24th Oct 2016 at 23:08
Did you do any hard breaking on the way home?
Pretty sure it does if you need anything for it mate I've got that phase 1 shell with pretty much everything intact?
Posted 24th Oct 2016 at 23:09
sergioiacobucci
No but dis have to weld a nut into a wheel bolt to get the locking ones out. I reckon its that
335i daily
Posted 24th Oct 2016 at 23:10
Perhaps but unlikely more likely you've clipped an abs sensor on the front or damaged it with the heat? Time to remove abs Smile
Posted 25th Oct 2016 at 08:16
sergioiacobucci
Exactly what i was thinking! I'll read up on how to do that
335i daily
Posted 25th Oct 2016 at 08:28
pug_306
Did you disconnect the battery when you welded onto the wheel nut?
1992 205 GTi6
205 Turbo 340bhp
Posted 25th Oct 2016 at 08:32
quite unlikely any welding caused any issues, check the system via the details in Autodata, theres an abs faq iirc.
Posted 25th Oct 2016 at 10:20
sergioiacobucci
Nope didnt disconnect the battery.
Maybe i just need to do an ecu reset? I cant plug it in as you know the ph1s dont have obd
335i daily
Posted 25th Oct 2016 at 11:43
mocinim
Check your abs ring bud make sure its not cracked if it has one ???
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 25th Oct 2016 at 12:40
sergioiacobucci
Yeh it does have a ring. Does it matter if i leave it and i dont care about having abs?
335i daily
Posted 25th Oct 2016 at 13:00
Not fail other than that no problem. Check you're brakes are working well before you do any over zealous manoeuvres mate Smile
Posted 25th Oct 2016 at 13:42
sergioiacobucci
Haha will do mate. Thanks for the info all!
335i daily
Posted 25th Oct 2016 at 15:05
RetroPug
A good idea would be to not take pictures at nearly 80mph on public roads.
Posted 25th Oct 2016 at 22:26
sergioiacobucci
Dont worrt mate it was on my driveway and my friend took the picture
335i daily
Posted 25th Oct 2016 at 23:11
cully
if you ran the car with the front wheels jacked up and rear wheels stationary, that is why the abs light is on
I had it with my ph2 would not reset untill i reset it with peugeot planet
Posted 26th Oct 2016 at 06:37
typically they will re-set after a few miles on the road.
Posted 26th Oct 2016 at 08:10
RetroPug
On my ph.1 this does occur with the front jacked up, but as said it always goes out again as soon as all four wheels are moved.
Posted 26th Oct 2016 at 20:46
mocinim
Had the same on the ph3 6 went out pretty quick once on the road
Posted 26th Oct 2016 at 20:52
RetroPug
Find someone with PP and see if it stays out when reset.
Posted 26th Oct 2016 at 21:06
sergioiacobucci
Thanks mate. Im not even sure how you plug these phase 1's in! Haha
335i daily
Posted 26th Oct 2016 at 22:04
