Author Subject: Missing retaining clip?
328isport
Hi Guys,
I've had my brake discs and pads changed all round in the last couple of weeks, I've had the feeling one of my calipers is binding ever so slightly since and after having a look at the stuff I can see, I've noticed a clip seems to be missing from the top of the outer pad on the drivers side, I'm presuming is to retain the pad? See pic below;
Is this something that can just fall out or is it more likely that the garage didn't fit it in the first place?
Next question is are these clips available separately?
Posted 19th Oct 2016 at 22:30
mocinim
Not likely to have fallen kut bud there pretty hard to remove and harder to replace
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 19th Oct 2016 at 23:29
328isport
Ah OK thanks, how annoying! Is my best bet to just get another set of pads then?
Posted 20th Oct 2016 at 09:25
oliverharveyuk@hotmail.co.uk
Posted 20th Oct 2016 at 10:00
328isport
Thanks Oliver, but I don't think they are the right type, mine look to be more like a small coiled spring which goes though the pad plate.
Posted 20th Oct 2016 at 10:28
might only be fitted to one end of the pad, check the other 3 pads.
Posted 20th Oct 2016 at 10:58
328isport
Yea I did check this just in case! Other front has a clip at both ends.
Posted 20th Oct 2016 at 11:46
Just ditch the lot and put 6 brakes on it. Cheap enough to pick up and the difference is night and day. Thumbs up
Posted 3rd Nov 2016 at 13:28
