Phase 1 silver track car335i daily
| Author | Subject: Injector removal? |
sergioiacobucci
Senior User Location: High Wycombe Registered: 27 Nov 2007 Posts: 526 Status: Offline |
Had a little search around and cannot seem to find much detail. How hard is it to remove the injectors? ________________________________________ Phase 1 silver track car335i daily |
two 10mm bolts and 4 plugs ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
What he said Then pull give a wiggle nice n easy bud Have some paper towel ready to catch fuel from the rail There wont be a great deal but expect some Then make sure u have all your seals ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
sergioiacobucci
Cheers! Thinking about sending them off for a clean and getting new seals________________________________________ Phase 1 silver track car335i daily |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
as said i personally roll them around very gently and pull while you have them out might be worth checking them to see if their starting to perish!________________________________________ Proud Member of the ASTOR Owners Club |
mocinim
gnrlee wrote: as said i personally roll them around very gently and pull while you have them out might be worth checking them to see if their starting to perish! In addition as always when trying to reinsert a rubber onto a tight hole a little bit of lube always helps I find it easiest to attach them to the rail first lube the bottom ring and then just a wiggle and a poke ![]() Cleaning is a good plan also ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
sergioiacobucci
Great thanks for the tips!________________________________________ Phase 1 silver track car335i daily |
mr injector can sort out testing cleaning and new seals, about £40 all in and decent turnaround.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
welshpug! wrote: mr injector can sort out testing cleaning and new seals, about £40 all in and decent turnaround. Any idea what sort of discounts he does for bulk loads ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
sergioiacobucci
welshpug! wrote: mr injector can sort out testing cleaning and new seals, about £40 all in and decent turnaround. Yep was looking into them based on comments on this forum. He only just reopened due to relocation ________________________________________ Phase 1 silver track car335i daily |
