Author Subject: Heavy clutch/ very low biting point
sageman
so my clutch has started to get very heavy and the biting point is very low i read on the forum about an auto ajuster that sometimes needs a little help or something i had a look but couldernt work out what to do
cheers
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 8th Oct 2016 at 13:27
mocinim
Robin rider hows it doing Smile
Try refitting the clutch cable or just fitting a new one they tend to rust a little at the bulk head the cable cuts into the rubber shroud also causing it to grip n get heavy the angle as it comes through the bulk head is crap and hard to fit correctly causing this issue fairly commonly
Try a dura cable if you dont want to pay out for a oem there around £20 see the fitting guide tie a cord around the white clip etc should take around half hour once jacked up
Easier to do on ramps Smile
I also grease mine at the pedal hole spray down the wire into the sheath and work it in it helps
Can operate my clutch with my fingertips genuinely
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 8th Oct 2016 at 14:02
any history of replacement?
probably needs one by now as the springs seem to stiffen up with age, the bushes wear and shafts rust.
Posted 8th Oct 2016 at 16:09
sageman
clutch was replaced less than 10,000 miles ago 2 years ago lots done
skimmed flywheel new fork bearings new oil new fork leaver at a cost of over £700
just now unclipped clutch cable from gearbox end and it dont seem stiff at all could be be something inside
1976 Reliant Kitten
1998 GTI-6
Posted 8th Oct 2016 at 17:48
mocinim
The cable wont seem stiff if theres no pressure/tension bud
If its not the cable however would suggest as welshpug has not much else to it
Posted 8th Oct 2016 at 18:33
sageman
yes good point
where do i get one then oh and how will that sort out the high biting point
1976 Reliant Kitten
1998 GTI-6
Posted 9th Oct 2016 at 11:02
mocinim
Biting point is it low or high ???
Check that the black plastic fitting is sitting correctly in the gearbox fiting point
If your cable is stretched it will be a little higher possibly
If your clutch isnt worn out ???
Got my last one from euro car parts
Also as mentioned the spring maybe stiff try lubricating it
Posted 10th Oct 2016 at 00:43
