Author Subject: Airbag Light Flashing
RetroPug
Ph.1 gti6, so only a driver's airbag and seatbelt pretensioners.
The airbag light is flashing. Previously, this has been solved by replacing the driver's seat connector, however, so far I have:
- Removed the driver's seat connector and soldered the wires together
- Soldered the passenger seat wires together
- Removed the resistor in place of the steering wheel airbag and re-soldered that to the wires
- Soldered one of the two plugs next to the ACU
- Unplugged and plugged the ACU back in
After all of this, it is still flashing. I could solder the other connector next to the ACU but I doubt that it is this. I have tried wiggling it, plugging it back in etc.
Are there any other things which can cause a flashing airbag light? Could a fuse be blown?
Posted 3rd Oct 2016 at 21:03
mocinim
Dry soldier ??? Did you cook any of the soldier to much
Have you checked the wire end connections at the pretentioners
They connect under the seat and at the tentioners
Orher than that you could check the wiring under the carpet
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 3rd Oct 2016 at 21:26
RetroPug
I didn't just join them with solder. I wrapped the wires around each other and then melted solder into them.
Posted 3rd Oct 2016 at 21:24
mocinim
mocinim has attached the following image:
Posted 3rd Oct 2016 at 21:31
RetroPug
Will check those, and that the pretensioners themselves haven't fired, thanks.
Posted 3rd Oct 2016 at 21:43
mocinim
Let me know if you find u fault bud
Posted 3rd Oct 2016 at 21:44
RetroPug
Those plugs on the pretensioners are tight. The pre-tensioners do not appear to have fired.
I have 2x 1.8ohm resistors that I can wire in in place of the pretensioners, under the seats, but I'm not too hopeful that this will work because I've already soldered the pretensioner wires together etc.
This car has been without an MOT because of this for a while now, to the point where I'm seriously considering stripping it, and putting a rollcage, harnesses and bucket seats in just so I don't have to deal with the constant electrical issues anymore. I've got an upcoming sprint day which I'm getting very close to having to miss now as well.
Is there anything else that can cause this? Is this system fused at all?
Posted 12th Oct 2016 at 18:58
RetroPug
1.8ohm resistors wired either side of the airbag control module where the connectors under the centre console are. All empty spaces on the fusebox filled with fuses just in case I moved one at some point.
Light still flashing....
Only thing I can think of trying is another airbag control module at this point...
Posted 14th Oct 2016 at 23:44
Ben_W
Formerly gpm
I'd doubt it was the control module.......
Deffo got the resistors in the right way round?
Posted 15th Oct 2016 at 07:30
cully
resistors are not polarised Wink
you have put them in the ecu side of the loom not pretensioners side?
also double check the steering wheel is resistor'd before the clock spring not in the wheel centre as the clock spring could be broken
i have known of a airbag ecu to go faulty and flash the dash light so it is possible!
to get an MOT on this i bypassed the ecu and fitted a time delay for the light the owner was aware Wink
Posted 15th Oct 2016 at 07:50
Cjwatson27
Strange I mine never failed it's mot and mine was flashing all the tester said was it's a old Peugeot no amount of airbags will save you if you crash
Posted 15th Oct 2016 at 08:21
mocinim
Should of failed bud but i get his point LOL
Posted 15th Oct 2016 at 08:23
RetroPug
Resistors are not polarised. They are on the ACU side not the pre-tensioner side, ie. they are wired to the ACU.
The clock spring is removed entirely, the steering wheel resistor is directly into the plug on the loom behind the steering wheel, which, when installed a year or so ago worked fine. I have cut it off and resoldered it though.
I would have doubted the control module but I'm running out of alternatives to try.
Posted 15th Oct 2016 at 08:31
cully
have you a multy meter just double check the fused resistors you have got, one may be open circuit
just a thought Sad
Posted 15th Oct 2016 at 08:46
RetroPug
Ok, worth a go. I did visually inspect them all and the fuses had no breaks, but I know that doesn't guarantee anything. I'm sure they are ok though.
Posted 15th Oct 2016 at 10:33
cully
first rule of electrical testing..
don't assume anything as it leads you up the garden path
Test it as there are 5 joints in the fuse resistor link from cable end to cable endWink
i have had a few duff fuses from new out the bag fuses
Posted 15th Oct 2016 at 10:50
If you wanted a quick "bodge" to get it through the MOT to avoid missing the sprint day, wire the airbag light on dash direct to a timed relay. So it comes on with ignition and then goes out after say 10 seconds.
A bodge obviously, but may get you out of a hole until you can find the real fault.
Posted 16th Oct 2016 at 12:11
pug_306
Just take the bulb out. It's not a mot fail. Simples
1992 205 GTi6
205 Turbo 340bhp
Posted 16th Oct 2016 at 18:17
RetroPug
My understanding was that if the light didn't come on with the ignition it is now a fail.
I'm aware of the various bodges that can be done to get it through an MOT. I'd rather not have to.
Posted 16th Oct 2016 at 22:37
get a code reader on it and see what it says, might be a completely different area
Posted 17th Oct 2016 at 09:59
This is correct. Yes
Posted 17th Oct 2016 at 17:15
pug_306
I don't think it is Smile
1992 205 GTi6
205 Turbo 340bhp
Posted 17th Oct 2016 at 17:28
cully
i read that as fail! if it indicates a fault
no lamp could mean be a pass and advise thats why i said ask your tester Thumbs up
Posted 17th Oct 2016 at 17:47
pug_306
Exactly it's a pass and advise. It used to be a fail. It changed in 2012 or 2013 iirc
It used to say if the bulb was inoperative it's a fail. Now it's not a fail.
1992 205 GTi6
205 Turbo 340bhp
Posted 17th Oct 2016 at 17:54
Yes, however the system functions by the lamp illuminating with ignition switch on and then going out if the system is working correctly.
The fact that the light does not illuminate (if the bulb was removed) shows that the system does have a fault as it is not working as designed, therefore would be a fail.
Posted 18th Oct 2016 at 09:35
