displaying posts 1 to 25 of 31
Author Subject: Stalls when hot
deeturbo
My car seems to have developed a stalling fault.
It has only happened a couple of time now, at first I thought it was me miss judging the clutch biting point after fitting a new clutch cable but I think it's definitely the car.
It's happened a few of times on the way home from work, once at some light, once at the junction and then when parking up.
When I'm off throttle and the revs should drop to idle that's when it stalls. The throttle body is clean, could it be the ICV or the green coolant sensor?
How do I clean the ICV? Might try that first.
Posted 24th Sep 2016 at 23:43
mocinim
Cleaning the icv rarely works usually best to replace it
It is however classic icv symptoms
Buy marelli!!!
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 25th Sep 2016 at 01:12
Robdog Rallye
Had the exact same problem, ended up being green ECU temp sensor.
Low boost Rallye
RB182 Cup
Posted 25th Sep 2016 at 06:34
manthos
I had the same problem and it was an air leak. split in the induction pipe. check for air leaks first before spending money on new icv or sensors
whilst engine is ticking over spray some Carb cleaner over air pipes and if the revs pick up theres a leak
Team SUPERCHARGED
Old Project thread
Posted 25th Sep 2016 at 10:28
aaron6
I thought air leaks generally made the cars rev up. Bit the resonator under the inlet manifold. They often crack.
Posted 25th Sep 2016 at 10:32
deeturbo
Thanks guys.
I shall check for air leaks as that can confuse the ECU and could cause issues like this.
I've got a feeling it'll be a temperature sensor going by the smelly exhaust when cold, think it's too rich when cold.
The lambda was changed in May and has only done no more then 1k (Bosch unit).
I'll buy a temperature sensor and ICV to keep as spares for future issues.
What sort of prices are people paying for a new Magneti Marelli ICV? This sounds like the MAF on the HDI, only the VDO unit is worth getting as cheap ones fail early. I've found a Marelli unit for £37, it's £140 at the dealers.
With the temperature sensors where would this be be bought, at dealers it's £74, I feel that's a bit pricey for what it is. Is there any particular make to go for on this?
Posted 25th Sep 2016 at 10:54
air leak on the intake pipe of these won't make a blind bit of difference, its a map sensor on the plenum so there aren't any sensors being bypassed.
Posted 25th Sep 2016 at 11:10
no sure where you got the £74 price from, theyre £24.
loads on ebay for much less though, including a few genuine items.
IIRC made by Jaeger.
Posted 25th Sep 2016 at 12:12
deeturbo
Oops, that's £74 was for a map senor.
£24 isn't too bad.
I'll check out eBay, thanks.
Posted 25th Sep 2016 at 12:57
manthos
mine did this and it was split intake pipe. changed it and problem went away
Team SUPERCHARGED
Old Project thread
Posted 25th Sep 2016 at 13:20
see my post above.
Posted 25th Sep 2016 at 15:05
manthos
That's what I replied to
Team SUPERCHARGED
Old Project thread
Posted 25th Sep 2016 at 15:50
intake pipe wont have any effect whatsoever
Posted 25th Sep 2016 at 17:35
deeturbo
Could someone please link me to a good temp sensor on eBay please.
Posted 25th Sep 2016 at 17:52
deeturbo
Would this temp sensor be ok?
click
Posted 25th Sep 2016 at 18:59
cully
part number 1920 K9 is £29.28 from peugeot without discount Wink
cant see ebay sat here in work its blocked Sad
put the part number into Amazon too you will be surprised what comes up cheaper than ebay Thumbs up
ECP Product Code: 224735281 £ 13.49
Posted 25th Sep 2016 at 19:15
getting a bit millitant blocking the mobile networks there arent they?!
Posted 25th Sep 2016 at 20:08
cully
dont carry my mobile at work Wink
Posted 25th Sep 2016 at 20:31
sergioiacobucci
£14 on amazon. This is the one I used when trying to solve cold start problems
Link
Phase 1 silver track car
335i daily
Posted 25th Sep 2016 at 21:06
deeturbo
After seeing Cully's post about Amazon I did a search and found that Magneti Marelli one and bought the last one.
I'll try the that sensor first then the ICV.
Does anyone know if the TPS is a track and wiper type sensor or a hall effect type like in the HDI's? Just thinking if it's a track and wiper type I might get one of them soon to keep as a spare.
Posted 25th Sep 2016 at 22:36
miki4
Simple potentiometer - track and wiper. Thumbs up Tested mine sending an audio signal (music) through it, varying the the throttle position (volume) and listening for rasping sounds or jumps in volume.
Posted 26th Sep 2016 at 02:18
deeturbo
I was hoping it wasn't a track and wiper as that tends to wear out.
I'll get a TPS next month as there is no doubt there will be a lot of where on mine.
That's a great way of testing it without a scope.
Posted 26th Sep 2016 at 21:16
deeturbo
Link
I got my temp sensor today but it didn't come with a seal, did your's come with one?
All the ones I've seen advertised, the pic's show the sensor with a seal.
Posted 27th Sep 2016 at 18:26
use the old one.
Posted 27th Sep 2016 at 18:31
deeturbo
I might have to for now but I don't like reusing old copper seals.
Think I'll get some m12 copper seals on order.
Posted 27th Sep 2016 at 19:28
