Author Subject: fuel pump funnel removal
russbez
advice required
it easy to remove? Need it removed to get access to derust the arch.
dont really want to damage anything, do not want to remove whole fuel tank (at the moment)
any do's and dont's?
i have very little fuel in the car just now, imagine i dont really want drop dirt in there
I take it i will be able to seal the fuel tank hole where the funnel meets the tank?
planning using some heavy fling film type wrap to keep dirt etc out
fuel flap looks to be just two 10/13mm bolts?
My Rallye project thread
Posted 19th Sep 2016 at 16:28
Ben_W
Formerly gpm
It's easy enough.
Couple of bolts. Iirc you don't need to remove the fuel flap. Bolts hold the neck to the car on the inside of the arch. A seal holds it to the fuel flap opening. Couple of fuel lines to disconnect. Worst bit is disconnecting it from the tank elbow, especially if it's a ph2 with those s**te pinch ring things.....
Just stuff an old cloth or something going the tank opening. If there isn't much fuel in it, I think you'll get away with leaving the elbow attached and just turning it upside down to stop crap getting in.
If you do end up removing the tank, derust the tank strap studs and bolts good and proper first. I sheared a stud taking my tank out. Be fun sorting that.
Posted 19th Sep 2016 at 22:25
russbez
thanks Ben, planning the tank another time
my bolts for the tank look like they are definitly going to snap Shut up
pinch ring is pretty rotten so will need to replace with decent jublie or something
Posted 20th Sep 2016 at 12:31
mocinim
Wire brush n recut the thread before you remove the nuts bud will save you all the trouble
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 20th Sep 2016 at 08:46
tvrfan007
Ben_W wrote:
It's easy enough.
I snapped one on my HDi years ago removing the brace. It still had 1xd of stud left over so i loctited the nut back into place and never had an issue.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 20th Sep 2016 at 14:00
Ben_W
Formerly gpm
Peugeot themselves superceeded them with a jubliee clip of some description, think it came un with the change to phase 3
Posted 20th Sep 2016 at 14:44
